mgf flat spot
  • rayb
mgf flat spot was created by rayb
Posted 13 years 5 months ago #24905
hi can anybody help, my mgf has started to hit a flat spot , it happens when im in traffic and stopped but as soon as i move off it hesitates so i have to increase the revs before it stalls. i have reset the throttle potentiometer to see if this helps, i have even changed back to the alloy 48mm throttle body, apart from this the car runs fine , i have changed the plugs rotar arm dissy cap and leads. the fuel filter was changed as well any advise please
Last Edit:13 years 5 months ago by rayb
Last edit: 13 years 5 months ago by rayb.
Replied by David Aiketgate on topic Re: mgf flat spot
Posted 13 years 5 months ago #24909
My first port of call would be to check whatever I did just before it started happening.
It could be so many things, fuel or electrical probably.
Check the plugs even if they're new. I spent ages trying to find a flat spot and discounted the plugs because they were new. Finally changed the plugs back to the old ones= no flat spot!
Check your engine in the dark, you may see stray electrical sparking around the dizzy/leads.:shrug:
Also try cleaning the iac valve. And make sure your idle speed is set up correctly.
Last Edit:13 years 5 months ago by David Aiketgate
Last edit: 13 years 5 months ago by David Aiketgate.
  • rayb
Replied by rayb on topic Re: mgf flat spot
Posted 13 years 5 months ago #24922
thanks dave have checked the plugs, i suspect it could be one of the leads, failing that will check the iac valve
by rayb
Replied by cjj on topic Re: mgf flat spot
Posted 13 years 5 months ago #24926
When was the air filter last changed?
  • rayb
Posted 13 years 5 months ago #24931
all fixed it was the high tension lead to the coil pack that was kaputt, visualy checked it and it was cracked, this was the only lead i didnt change as it is a bugger to get to. :woohoo:
by rayb
Posted 13 years 5 months ago #24932
That's good to know. :yesnod: I'll file that knowledge away for future reference. :thumbsup: :lol:
Time to create page: 0.490 seconds
