Proud of this solution
Proud of this solution was created by Nightfire Red
Posted 13 years 5 months ago #25179
OK, The rear subframe is dropped - check.
The drive shafts have been removed - check ( thanks again Clive!!!! ).
The engine and gearbox are ready to lift out of the subframe- check
Now I might as well get the crank pulley bolt out as I'm going to change the head gasket and water pump ( both the cam belt and tensioner are less than 1,000 miles old ). But how am I going to lock the flywheel?
I don't know about you, but I think the flywheel locking tool is rather expensive for the job that it does and isn't easily available. So here comes the ingenious part ( well I think so anyway ).
Remove starter motor and buy an extra one of these for £3.99
Insert the spare cam locking tool as shown here
Ensure the locking tool doesn't slip as you start to take up the slack on the torque wrench. once the slack is taken up the tool will not slip out as its jammed up agains the gearbox bell housing, and it is locked into the teeth on the ring gear. Undo the bolt as you normally would do with the torque wrench.
Hope this is useful.
Rob
Last Edit:13 years 5 months ago by Nightfire Red
Last edit: 13 years 5 months ago by Nightfire Red. Reason: change file extension on one of the picture to JPEG
Replied by gotenks1321 on topic Re: Proud of this solution
Posted 13 years 5 months ago #25180
Looks good :thumbsup: I just bought the proper tool from MS as I was ordering a load of other bits from him at the time :lol: I've also managed to drop the odd bolt into the gearbox through the starter hole so wouldn't want to risk dropping one of those too :silly:
Last Edit:13 years 5 months ago by gotenks1321
Last edit: 13 years 5 months ago by gotenks1321.
Replied by David Aiketgate on topic Re: Proud of this solution
Posted 13 years 5 months ago #25181
Certainly a cheaper solution than MSatur's £27 tool! :thumbsup:
Replied by Nightfire Red on topic Re: Proud of this solution
Posted 13 years 5 months ago #25182
A very valid point about droping the said tool into the bell housing.
As can be seen in the picture there are 2 holes in the cam locking tool. A piece of wire or string could be attached through the holes and tied off somewhere, thus allowing you to remove the tool if it drops down into the bell housing.
( He say's this as if he had already thought of that problem prior to it being pointed out by Gotenks1321 ....................................................................................................................................but he hadn't :whistle: :thumbsup: )
The following user(s) said Thank You: David Aiketgate, tich65a
Posted 13 years 5 months ago #25187
I knew those holes served a purpose! :whistle: :lol:
Time to create page: 0.509 seconds
