slow pick up
- greenmgfman
- Novice MGer
hi ive just had some one drive my 2001 mgf vvc and he thinks its slow to pick up and the engine is making too loud of a tapping. ive heard other mgf,s and they all sound alike but as the pick up ive never driven other mgf,s so not sure . the car its self only picks up if you keep it above 4500rpm and go,s quick so iam not sure if there is a problem. if any one can help that would be fab the lad who had a go had a mgf vvc but now has a tf thanks
by greenmgfman
As a 2001 I would think its Mems3. If so then My first port of call would be to get an OBD2 reader on it, and see what comes up. This will point to any problems.
Has the car always been the same, or is this slow pickup recent? If so what work has been done in the interim?
Slow pick up could be timing, has it had a Cambelt change recently?
What are your actual revs limited to on your car at the moment? 7200?Or less?
- bryan young
David Aiketgate wrote: As a 2001 I would think its Mems3. If so then My first port of call would be to get an OBD2 reader on it, and see what comes up. This will point to any problems.
I Wonder if this could be an oil pick up problem??? the loud tapping is the cam followers being starved of oil (simmilar to Kevin's with the black tar in the sump) Kevin did say that the performance was down, which is consistent with the followers not opening the valves properly. :omg:
by bryan young
Time to create page: 0.505 seconds
