Correct Oil Temperature on an MGTF
Correct Oil Temperature on an MGTF was created by bryan young
Posted 13 years 4 months ago #26683
Is it correct that the normal temp of oil should be at 80 deg C, was asked yesterday and was not sure. The needle is on the second mark between 60 and 120 or is that 90 ?? :shrug: :-?
Replied by Tsleight on topic Re: Correct Oil Temperature on an MGTF
Posted 13 years 4 months ago #26687
Mines an F with 100 000 miles on the clock and the oil just creeps above 60! Don't know whether thats good or bad, but the water temp is spot on: just below half way.
Tim
Replied by David Aiketgate on topic Re: Correct Oil Temperature on an MGTF
Posted 13 years 4 months ago #26690
The problem is that the oil temp gauge is well known for its 'individual' behaviour.:lol: They indicate temp, rather than show exact readings
I think ours reads 60-90 generally, and 100-10 if you give the car a good thrashing!
As long as the readings on your gauge are consistent in the way it moves with harder use, don't worry!
The following user(s) said Thank You: bryan young, Tsleight
Time to create page: 0.481 seconds
