Front upper ball joint help.
Replied by petevick on topic Re: Front upper ball joint help.
Posted 13 years 2 months ago #27774
I use a 1/2" drive 46mm (1 13/16") deep socket with one of these bad boys on the end -
whips them out in no time at all.
Pete Vickerstaff
Last Edit:13 years 2 months ago by petevick
Last edit: 13 years 2 months ago by petevick.
The following user(s) said Thank You: xad3888
Replied by xad3888 on topic Re: Front upper ball joint help.
Posted 13 years 2 months ago #27775
I like the look of that 12v chatter gun. Where can I get one?
The length of my response was in direct proportion to the frustrations of getting stuck ball joints etc out of my car. It's satisifying to get a job done on your own with ordinary tools - but a heck of a lot easier with the right ones!
Jeff
Last Edit:13 years 2 months ago by xad3888
Last edit: 13 years 2 months ago by xad3888.
  • Visitor
  • Visitor
Replied by a Guest on topic Re: Front upper ball joint help.
Posted 13 years 2 months ago #27776
how take off ball joints and we do it a around 10 times a week. take off the top bolt from the ball joint,cut the ball joint off,the bit that goes through the suspension .we have a rover tool and we also have a set of inch drive sockets.
place the socket over the ball joint remains,and hammer it on to the ball joint.then with a big bar undo the top ball joint.
Because the ball joints are kept in with a tread hold compound there dont suffer from rusting.and your replacements must also have tread holder applied as well.
As a company we never use wd40 plus gas any where around customers brakes.Our cars have to be in and out so the customer can have there car back.
But if you place a right size socket and good size bar then it will come off easy promise
Posted 13 years 2 months ago #27777
xad3888 wrote: I like the look of that 12v chatter gun. Where can I get one?........Jeff
loads on ebay - http://www.ebay.co.uk/sch/i.html?_kw=12v&_kw=impact&_kw=wrench
Pete Vickerstaff
Replied by David Aiketgate on topic Re: Front upper ball joint help.
Posted 13 years 2 months ago #27778
I got one of these, but it stopped working after a couple of months.
12V Impact Wrench Digital Display & Torque Config
Completed
So I bought a 240v one from Machine Mart instead. impact driver
Last Edit:13 years 2 months ago by David Aiketgate
Last edit: 13 years 2 months ago by David Aiketgate.
Posted 13 years 2 months ago #27779
nice piece of kit David :thumbsup: that would be my route if ever my Maplin £13 bargin gives up :yesnod:
Pete Vickerstaff
Time to create page: 1.597 seconds
