urrrggg... more problems...
i make it though the tunnel at about 5000rpm all the way though (still stuck with the 1 gear ratio) and pull over just as my water temps hit the red marker, and the oil hits about 140C...
i pop the boot open, and try to cool the engine as best i can, switch it off for about 30 mins total, in which time i started it 3 or 4 times to circulate the coolant so i didnt get hot spots....
car seems fine again now, but the engine bay fan seems to be dead and not kicking in.... (the one that blasts air out of the drivers side engine inlet)
is there a fuse for this? is it a faily common issue, and can i get a replacement fan if need be (and where from?)
any help appreciated...
Oz.
- a Guest
- Visitor
Engine light is on, clear the error code and it stays off untill i hit stationary traffic for more than about 2 minutes, then comes back on again...
not sure if its a heat soak thing, but im sure its related to the fan not working and not getting rid of the high engine bay temps....
i have a bluetooth ODBII reader perminantly connected to the ODBII port, engine temps seem fine all the time, inlet temps seem a little high, often going up to 50C or so in slow moving traffic, again i think related to engine bay not getting rid of the heat...
Oz.
Replied by David Aiketgate on topic Re: urrrggg... more problems...
Posted 13 years 2 months ago #28523If so disconnect the sensor plug and the fan should run when the engine's started.
sensor
Posted 13 years 2 months ago #28525David
Yes it has got the temp sensor above the expansion tank.
Will check fuses /relays... Where are they located?
Oz
Maybe when the temp is getting high the fan circuit is kicking in and blowing fuses/shorting to earth. The fan or associated wiring may be shorting to earth or seized.
Obviously, if you don't have a fan it will overheat in traffic.
I know from experience that lack of voltage switches off your EPAS etc. Also there is a question at the minute about low voltage and the action of the ECU that controls the gearbox. Does it go into limp home mode?
then i lose the power steering, and the rev needle drops to 0, even though the engine is running fine, and then the gearbox locks to 1 ratio and your effectively stuck in 1st with a speed of about 20mph at 5000rpm...
and as i found out running at 20mpg through dartford tunnel results in very hot water and oil...
car has been fine since, but not hit any stationary traffic at all since either...
Oz
I would let it run on the driveway until it reaches temp. See if the fan cuts in or if it all goes to crap again.
If the fan doesn't come on I think it might be the problem.
Posted 13 years 2 months ago #28606David Aiketgate wrote: Check fuse 6 under the steering wheel and also relay 3 (The one above the heated rear window relay position)
something weird going on...
anyone know if i could wire in an extra fan in parrallel with the existing one to blow hot air out the top grills of the boot lid, as the fan by the drivers side rear engine intake is just blowing cold air out and not getting the hot air out...
Posted 13 years 2 months ago #28695Why not try running with the engine bay sensor disconnected?
Then the fan will run constantly when the engine's running.
It may be that the sensor is not activating at the correct temperature. :shrug:
