rear fog light mgtf
  • rayb
rear fog light mgtf was created by rayb
Posted 13 years 2 months ago #28526
i wonder if some one can point me in the right direction, i have a mgtf and would like to fit my rear quad lights with leds, im looking at moving and fitting the rear fog light to under the number plate so i can have 2 reverse lights on the quad instead of 1. would this be legal having the fog light positioned here
by rayb
Replied by David Aiketgate on topic Re: rear fog light mgtf
Posted 13 years 2 months ago #28527
rayb wrote: i wonder if some one can point me in the right direction, i have a mgtf and would like to fit my rear quad lights with leds, im looking at moving and fitting the rear fog light to under the number plate so i can have 2 reverse lights on the quad instead of 1. would this be legal having the fog light positioned here
This is what the regs say:-
Fog lamps
Rear, regulations
Regs for rear fogs are as follows:
Must be fitted to cars manufactured after 1/10/79 and registered after 1/4/80 (this means that cars manufactured before 1/10/79 but registered after 1/4/80 are exempt).
Any car which has rear fog lights fitted which falls after the above dates must comply with the following regulations.
No more than two fitted.
If one is fitted it must be on the centre line of the vehicle or to the right (viewed from the rear).
They should not be mounted so as to dazzle other road users.
If two are fitted both must work.
Maximum power of 24W.
They may only illuminate when headlights (main or dip) are illuminated.
Must be over 100mm from the brake lights (there are several production cars that break this rule).
Time to create page: 0.469 seconds
