TF ECU SWAP 115 <> 135
TF ECU SWAP 115 <> 135 was created by Titanium
Posted 13 years 2 months ago #28654
I'd like to better understand the possibility to swap the MEMS ECU between 115 and 135 hp or viceversa.
In Italy Rover sold 1800 TF 115 versus 180 TF 135.
So find parts for my 135 from breakers is not evident, I found several 115 sold as spare parts.
What do I've to do to swap a 115 ecu into my 135 ?
What about the other electronic devices: anti thief, epas, being all interlinked among them
Replied by David Aiketgate on topic Re: TF ECU SWAP 115 <> 135
Posted 13 years 2 months ago #28666
I don't think it is possible. The 115 has different fuelling, different head, different throttle body to the 135. To change to the 115 ecu you would need to change all this on your 135 to match.
Replied by Titanium on topic Re: TF ECU SWAP 115 <> 135
Posted 13 years 2 months ago #28668
David Aiketgate wrote: I don't think it is possible. The 115 has different fuelling, different head, different throttle body to the 135. To change to the 115 ecu you would need to change all this on your 135 to match.
This was my doubt, but it should be possible to replace the original software or better the data base with the original parameters.
So the right thing should be to create a back up of the ecu.
Replied by Supercover on topic Re: TF ECU SWAP 115 <> 135
Posted 13 years 2 months ago #28669
The physical ECU should be the same, its just the map data inside that is different between them.
cjj wrote: Supercover has been nominated for the Nobel Peace Prize.
Social hand grenades don't exist. ;)
  • Visitor
  • Visitor
Replied by a Guest on topic Re: TF ECU SWAP 115 <> 135
Posted 13 years 2 months ago #28673
we change engine to diff specs all the time,you must change ecu alarm and check your injectors are the same
Posted 13 years 2 months ago #28733
Uhmmm could you pls be more detailed:
what do you means " change engine specs all the time" ?
change ECU alarm I know the alarm code are resident in the ECU
So basically suppose I've a MEMS3 ECU from a TF115 and I want to install it on a TF135, what exactly do I've to do ?
Grazie mille
Time to create page: 0.497 seconds
