Rear wheel arch liners
Rear wheel arch liners was created by mowog73
Posted 13 years 1 month ago #28789
I recently discovered that my F is missing the both rear wheel arch liners. I found a picture of what the right hand side liner is suppose to look and last night I set about and made one from sheet metal. It’s not exactly the same as the original but it will do the trick; it will keep dirt and water away from the alternator.
But I have not been able to find a clear picture of the left hand side rear wheel arch liner. From the picture I have found it looks like it has louvers in it. Does someone have a picture of the left hand side liner that they could share with me?
[size=10pt]Mark[/size]
95 MGF
by mowog73
Replied by David Aiketgate on topic Re: Rear wheel arch liners
Posted 13 years 1 month ago #28791
The left hand side one on mine didn't have louvres in it.
It was one unadulterated piece of soggy cardboard type material.
The right one had disappeared before I bought the car.
I replaced them both with two covers from redundant plastic boxes.
You can see part of the driver's side one here. Outlined in orange dots.
Replied by mowog73 on topic Re: Rear wheel arch liners
Posted 13 years 1 month ago #28881
The other night I decided to go out and make my own for the driver's side. Using cardboard to make a template, I cut a new one out of sheet metal, put a couple bends in it with my brake and within an hour a new one was made. Not as pretty as the original but didn't cost me a 20 either.
95 MGF
by mowog73
The following user(s) said Thank You: buzzbee, xad3888
Replied by Leigh Ping on topic Re: Rear wheel arch liners
Posted 13 years 1 month ago #28883
mowog73 wrote: Not as pretty as the original but didn't cost me a 20 either.
Prettier than the rest of it under there. :) Good job.
Last Edit:13 years 1 month ago by Leigh Ping
Last edit: 13 years 1 month ago by Leigh Ping.
Posted 13 years 1 month ago #28884
I was thinking the same thing Leigh when I posted the picture this morning. Once I get the clutch bled and the car back on the road, I'll spend some time cleaning and painting the rear sub frame. I also have spot of rust to fix on the passenger side as well.
95 MGF
by mowog73
Replied by buzzbee on topic Re: Rear wheel arch liners
Posted 13 years 1 month ago #28885
mowog73 wrote: I was thinking the same thing Leigh when I posted the picture this morning. Once I get the clutch bled and the car back on the road, I'll spend some time cleaning and painting the rear sub frame. I also have spot of rust to fix on the passenger side as well.
Great job there, well done that man.
If my info is correct MGR never made a cover for the near side, just the off side to try and protect the belts. A "soggy cardboard" type thing on the F and a moulded plastic jobby for the TF. I am on my second for the TF, not quite sur e what happened to the first
Stu
by buzzbee
Posted 13 years 1 month ago #28909
Stu
As the nearside ''soggy'' was still attached to my car, I'm sure they did make and fit them at some point, :yesnod:
The offside one had been reduced to a couple of tabs around the fixing screws. :nonod:
Time to create page: 0.535 seconds
