Engine light...
Engine light... was created by Ozzy
Posted 13 years 1 month ago #29180
Keep getting PO170: Fuel Trim Malfunction (Bank 1)
any ideas what this actually means?
always the first time i put my foot down then lift off after accellorating up slip-road on to the A3 in the mornings...
getting annoying now, car is running fine (except cooling issues)...
any idea what that code specifically referes to? injectors? or mapping? or overrun?
just want to know what i need to do to sort it out...
thanks
Oz.
by Ozzy
Replied by eagle on topic Re: Engine light...
Posted 13 years 1 month ago #29182
Found this item on the net , might be helpful.
http://www.obd-codes.com/p0170
I wish
THe Lone Gunman
by eagle
The following user(s) said Thank You: psymon
Replied by Ozzy on topic Re: Engine light...
Posted 13 years 1 month ago #29221
thanks, sounds like i will have to live with that then...
i have an emerald ECU doing the fueling, so chances are its putting in more fuel than the stock ecu would allow and throwing the error code, even though the A/F is perfect ratio, and the car is running flawlessly...
annoying...
by Ozzy
Replied by David Aiketgate on topic Re: Engine light...
Posted 13 years 1 month ago #29225
eagle wrote: Found this item on the net , might be helpful.
That's a very informative website. :yesnod: Well done for finding that :thumbsup: I'll put a link in the A-Z of How tos.
Replied by bryan young on topic Re: Engine light...
Posted 13 years 1 month ago #29299
Thought i had seen that MGF before !!! it is the one taken from the original scheme sketch by Gerry McGovern, i have a copy of the limited edition print :omg:
Time to create page: 0.500 seconds
