Tyre Woes.
Tyre Woes. was created by cjj
Posted 13 years 1 month ago #29552
Well, I took the OSR tyre off while I was playing with my suspenders and noticed this on the inside edge.
I take it that this isn't normal? :lol:
Replied by Laz1957 on topic Re: Tyre Woes.
Posted 13 years 1 month ago #29559
It's lucky you noticed that - whew! :omg:
by Laz1957
Replied by eagle on topic Re: Tyre Woes.
Posted 13 years 1 month ago #29565
What mileage has that tyre done ?
I wish
THe Lone Gunman
by eagle
Replied by cjj on topic Re: Tyre Woes.
Posted 13 years 1 month ago #29570
About 12,000 miles (Hard miles) over 2 years. Mixture of country roads etc.
Posted 13 years 1 month ago #29574
I have managed to buy 2 new 215/40/16 Toyo Proxes from BlackCircles.
The order has gone through and I have a provisional delivery date of 18 Oct
Tyre detail: Toyo Proxes T1-R 215/40 R16 W (86), Reinforced * 2
Scheduled delivery date: 18/10/2011
A full confirmation will be sent once our team has processed your order.
However, I'm half expecting to get an e-mail tomorrow saying they have none in stock. :unsure:
Replied by Dieter on topic Re: Tyre Woes.
Posted 13 years 1 month ago #29576
Looks strange.
Two *May be* ideas:
1 - to much toe out \--^--/ <--- axle&wheels seen from top. Driving direction: ^
Inner edge tyre wear
2 - to less tyre pressure
Dieter K.
MGF Rep. MGCC DE
[IMG
by Dieter
Replied by David Aiketgate on topic Re: Tyre Woes.
Posted 13 years 1 month ago #29578
That looks more like something rubbing.
Excess camber/ tracking usually gives a more gradual wear pattern.
Replied by Tigger on topic Re: Tyre Woes.
Posted 13 years 1 month ago #29582
I think David's right - may be linked to the problem with the ride height at the rear?
Could the spring be bowing outward and rubbing on the tyre?
by Tigger
Replied by bryan young on topic Re: Tyre Woes.
Posted 13 years 1 month ago #29617
Dieter wrote: Looks strange.
Two *May be* ideas:
I would go for 2 ~ i had a simmilar problem on my Honda Accord on the rears at 45,000 miles, the standard camber angle tips the tops of the wheels inwards (wear on inside) and pressures were 30psi ~ handbook says 36psi, which they are now at. tyres were Avon ZV3 and had been on the front for first 10,000 miles.:shrug:
Posted 13 years 1 month ago #29690
Tyre pressures were OK and 4 wheel allignment is done regularly.
I tend to corner hard which may not help.
I now have 2 brand new rear Toyos sitting in my garage which cost me less than £60 each.
I will give it a good check over before fitting the new tyres.
Posted 13 years 1 month ago #29698
cjj wrote: Tyre pressures were OK and 4 wheel allignment is done regularly.
That is a good price for TOYO's :thumbsup: my local tyre fitter is charging £76 fully fitted with new valve and balanced. has recently done two TFs on my reccomendation and i dont get commission!! :yesnod:
Time to create page: 0.513 seconds
