Seized Top Damper Bolt
  • GIR
  • Apprentice MGer
  • Apprentice MGer
Seized Top Damper Bolt was created by GIR
Posted 13 years 1 month ago #29770
Does anyone have any ideas as to how to release a top damper bolt short of using a plazma cutter?!!!! :rant:
by GIR
Replied by petevick on topic Re: Seized Top Damper Bolt
Posted 13 years 1 month ago #29772
you could try a nut splitter, failing that, drill down thru the nut, then attack with a chisel.
Pete Vickerstaff
The following user(s) said Thank You: Leigh Ping, GIR
Replied by David Aiketgate on topic Re: Seized Top Damper Bolt
Posted 13 years 1 month ago #29773
If you or a lovely assistant can get a grip of the damper body to prevent it turning, that usually allows you to exert sufficient torque to loosen it.:shrug:
The following user(s) said Thank You: GIR
  • GIR
  • Apprentice MGer
  • Apprentice MGer
Replied by GIR on topic Re: Seized Top Damper Bolt
Posted 13 years 1 month ago #29774
Even with an ugly assistant couldn't get it to budge. :lol:
Socket on a hammer drill ended up doing the trick! :woohoo:
by GIR
Replied by xad3888 on topic Re: Seized Top Damper Bolt
Posted 13 years 1 month ago #29775
On two of my shocks, I found the nut rotated without coming undone, even when gripping the outer casing of the shock itself.
A nutsplitter is a good idea although I got a similar and less brutal result with a Dremel and cutting disc(s). A couple of cut slots will weaken the nut's grip enough to break it apart with a stout screw driver. The shock absorber will come out undamaged if you are careful not to cut into it's threads. In my case the shocks were worn out anyway, so I could have been a bit more aggressive with their removal. I replaced with Gaz adjustables.
Jeff
by xad3888
  • Visitor
  • Visitor
Replied by a Guest on topic Re: Seized Top Damper Bolt
Posted 13 years 1 month ago #29827
the joys of mgf rust rust and more rust
  • GIR
  • Apprentice MGer
  • Apprentice MGer
Posted 13 years 1 month ago #29832
Rust isn't really an issue over here but then we don't have snow or salted roads to contend with. ;)
by GIR
Time to create page: 0.493 seconds
