MOT this morning.
MOT this morning. was created by David Aiketgate
Posted 13 years 1 month ago #29791
..and passed! With only one advisory for play in N/SF lower ball joint. Oh, and an Italian tune up to get the emissions to pass.
I had an interesting chat with the tester about matters relating to our world.
According to him blocked-out brake callipers with bigger discs should not be a problem, as long as they are efficient enough and fitted securely. :thumbsup:
Also said that the Epas pull left shouldn't be a fail. Taking out the fuse to disable the power steering would be a fail, however. :nonod:
New to the MOT - Brake balance test will now include the rear brakes as well as the front.
Replied by Tsleight on topic Re: MOT this morning.
Posted 13 years 1 month ago #29793
Well done! :thumbsup:
Replied by GIR on topic Re: MOT this morning.
Posted 13 years 1 month ago #29801
Well done!
Thankfully we don't have to jump through those hoops here in Queensland..... yet. Southern states do so probably only a matter of time.
Last Edit:13 years 1 month ago by GIR
Last edit: 13 years 1 month ago by GIR.
Replied by bryan young on topic Re: MOT this morning.
Posted 13 years 1 month ago #29802
Great News :woohoo: :woohoo: I thought the brake balance on the rears was always in the previous test?? my testing station has always run the brake tester on each back wheel in turn as well as the fronts, perhaps it is just the way they do it :shrug:
Get that lower ball joint done before it get worse and buggers a tyre :rant:
Replied by David Aiketgate on topic Re: MOT this morning.
Posted 13 years 1 month ago #29813
bryan young wrote: Great News :woohoo: :woohoo: I thought the brake balance on the rears was always in the previous test?? my testing station has always run the brake tester on each back wheel in turn as well as the fronts, perhaps it is just the way they do it :shrug: They test each brake but up until now there was no balance figure between the back brakes. The front brakes have to be within 25% of each other. This is now extended to the rears (same 25%)
This time my fronts were only 7% imbalanced and the rears were 15% so the car would have passed the rear test. :yesnod:
TOO LATE Bryan! o/s/ tyre was near the limit. Inner edge worn. :rant:
  • Visitor
  • Visitor
Replied by a Guest on topic Re: MOT this morning.
Posted 13 years 1 month ago #29824
we have a car in for mot it needs all ball joints,two tyres,brakes,window screen,rear light lens,wish bones,anti roll bar rubbers,and new cat .what fun.
Posted 13 years 1 month ago #29830
dazlightyear wrote: we have a car in for mot it needs all ball joints,two tyres,brakes,window screen,rear light lens,wish bones,anti roll bar rubbers,and new cat .what fun.
Apart from that...perfect. ;)
Posted 13 years 1 month ago #29833
Ouch, that sounds a very expensive MoT ~ how did it get that bad in a year!!!!!! :rant: but as David said "otherwise perfect"!! :omg: :bust:
Time to create page: 1.145 seconds
