Speedo milage memory
This brings me to the question - is the car's milage stored in the speedo itself or in the ecu. In other words will the replacement show the milage off the donor car or off my TF?
Tigger wrote: ..... This brings me to the question - is the car's milage stored in the speedo itself or in the ecu. In other words will the replacement show the milage off the donor car or off my TF?
Mileage stored in the speedo so will be that of the donor.
Thanks Paul - well it was a cunning plan :lol: mind you I quite fancy having a 30K car again :whistle:
- bryan young
Tigger wrote: [quote="PQD44" post=29811Mileage stored in the speedo so will be that of the donor.
Thanks Paul - well it was a cunning plan :lol: mind you I quite fancy having a 30K car again :whistle:[/quote]
:rant: :rant: The past electronic MoTs will show the correct mileage, could this be a problem with future MoTs??? :whistle:
David Aiketgate wrote: Hence - clocking! :coat:
True, but we're not talking about turning the dials with a small screw-driver anymore :oops: - they work on that new fangled electrickery stuff now :bust:
MG TF LE500 27 of 500
- a Guest
- Visitor
Click here for the how to
To remove the instrument cluster you don't even need to remove the steering wheel, it's tight, but can be done. Fit your replacement unit temporarily, revamp your existing speedo dials then refit. :thumbsup:
PQD44 wrote: Tigger - why not follow David's how to on the dials
Now THAT is a cunning plan! Sorted - thanks again Paul :thumbsup:
