Damp Backside
- Rich in Vancouver
This morning I went out to find this :pinch: .....
Seems it's coming in at the intersection of the top, windshield frame and the window. The window is nice and snug (new window stop last week), and the top is a MK2 type with the extra bit on the corner. Any tips on how to preserve my dignity?
- Rich in Vancouver
Thanks for suggesting I take pictures of the leak area. Sometimes the lens point out things that the eye misses.
I think for now I will add a bit of closed cell foam in the corner and see if that does the trick. I have a hardtop coming in the next month or so and will do a proper window adjustment then.
Cheers, Rich
This inside pic reveals the source of my discomfort!
So here it is in a nutshell, the window adjustment is a long way out. :omg: Have a look in my useful pics folder there are a couple of photos in there of my window/seal.
Attachment not found
Attachment mgtfheadgasket043.JPG not found
This is the glass as it approaches the seals
Attachment mgtfheadgasket044.JPG not found
Rich in Vancouver wrote:
.......... Any tips on how to preserve my dignity?
:yesnod: Yes, Rich for goodness sake, please vacuum, dust and then use a good quality interior valet product on your car before taking photo's to put on the world wide web :broon:,
You'll give MG owners a bad name, call yourself the Canadian rep of the Register, they'll revoke it if this is your standard of presentation :lol:
- terreneuve
- Rich in Vancouver
- adamelphick
They are easy enough to change - you need to pry up the front corner of the hood material and you can see the little tag that holds them. There is a small locking bolt that it passes through at the rear. If it is broken I can guarantee you will need to 'clear out' the channel it runs through as it tends to rust away into little bits!
- Rich in Vancouver
Must be the Pininfarina involvement.
- Leigh Ping
Rich in Vancouver wrote: Must be the Pininfarina involvement.
1958 BMC Farina cars - Austin A55 Cambridge Mk II, MG Magnette Mk III, Morris Oxford V, Riley 4/68, Wolseley 15/60 -
1965 MGB GT -
1995 MG F - Roof Structure only
