Stupid naive question....spring washers
  • Visitor
  • Visitor
Stupid naive question....spring washers was created by a Guest
Posted 13 years 3 weeks ago #30711
The toyosports SS manifold came with a load of spring washers...which I never bothered to fit, I just used normal SS washers.
Now I have discovered my manifold is leaking at the downpipe joint and some of the bolts have worked loose. As they are not fixed at the top, cant tighten them from the bottom only so will have to dismantle car again.
Anyway, question is, should I have used spring washers? What are they for? Where do they go lol!
No point in tightening them all up again if they are going to come loose soon after
Replied by PQD44 on topic Re: Stupid naive question....spring washers
Posted 13 years 3 weeks ago #30713
Partial answer - spring washer also known as a lock washer is used where parts are subject to vibration and/or tension that may cause the nut to work loose, so they .. well stop the nut working loose... as you have... errr discovered :unsure:
:nonod: the only stupid naive question is the one you don't ask :thumbsup:
Last Edit:13 years 3 weeks ago by PQD44
Last edit: 13 years 3 weeks ago by PQD44. Reason: clarity
  • Visitor
  • Visitor
Replied by a Guest on topic Re: Stupid naive question....spring washers
Posted 13 years 3 weeks ago #30714
Cheers. will refit wiht the springs then...
do you know if they go over a normal washer? ie. normal washer/spring washer/bolt
or just between manifold and bolt
Posted 13 years 3 weeks ago #30717
Use in the order - surface to which you are fixing - flat washer - spring washer - bolt/nut :broon:
Having said that you can use the spring washer alone. I would use a flat washer in the cobination if I was fixing to a soft surface say wood or plastic
The following user(s) said Thank You: a Guest, Leigh Ping
  • Visitor
  • Visitor
Posted 13 years 3 weeks ago #30718
Brilliant..thanks!!!
I did try one when I first fitted it and it didn't seem right on its own so will put in between flat washer and bolt....
Might as well get it done whilst the sun shines
Posted 13 years 3 weeks ago #30720
broon wrote: .... Might as well get it done whilst the sun shines
So that will give you about 10 mins or are you not a home or have you relocated :lol:
  • Visitor
  • Visitor
Posted 13 years 3 weeks ago #30721
:P
Replied by David Aiketgate on topic Re: Stupid naive question....spring washers
Posted 13 years 3 weeks ago #30724
This is one of the disadvantages of using SS nuts and bolts. They tend to come loose, as they don't rust together like the standard bolts. :unsure:
Replied by bryan young on topic Re: Stupid naive question....spring washers
Posted 13 years 3 weeks ago #30736
broon wrote: Cheers. will refit wiht the springs then...
I would only fit the split spring washers supplied as the sharp bit of the oblique cut spring washer cuts into the two faces of manifold and nut stopping them vibrating loose. you could also us a drop of the proper type of LOCKTITE ~ the use of a plain washer could mean that plain washer/spring washer/nut combo could turn together and still become loose. :rant:
You could also pm Daz to ask how he fits them :shrug:
  • Visitor
  • Visitor
Posted 13 years 3 weeks ago #30757
bryan young wrote: I would only fit the split spring washers supplied
That's where my next homer award comes in....I threw them out! Doh!
Got some new ones today though but by the time I had negotiated a pre-christmas city , it was getting dark by time I got back so will have to wait till tomorrow....
Interestingly, took the F and it was as bad today, the noise was "normal" and it didn't sound like there is a leak, but there is a smell of exhaust fumes in the cabin so it must be. Also it seems to idle higher until warmed, whcih only started after I fitted it and ran about for a while
Last Edit:13 years 3 weeks ago by a Guest
Last edit: 13 years 3 weeks ago by a Guest.
Posted 13 years 3 weeks ago #30759
How many Homers can one man take?:shrug:
  • Visitor
  • Visitor
Posted 13 years 3 weeks ago #30760
Ive got 7 properties round the globe to accommodate them
IN fact I might just change my name by deed poll
Time to create page: 0.510 seconds
