windscreen washer just aint a-washin no more!
windscreen washer just aint a-washin no more! was created by a Guest
Posted 16 years 8 months ago #3114
my washer is full of water, and it makes all the right noises, but no water comes out! does anyone have some magic answer for me that doesnt involve taking it all apart? :dunno:
Replied by jonnocash on topic windscreen washer just aint a-washin no more!
Posted 16 years 8 months ago #3115
have you tried putting a pin in the jet and have someone opperate the washer?
Replied by David Aiketgate on topic windscreen washer just aint a-washin no more!
Posted 16 years 8 months ago #3116
Known problem areas are the pipes getting full of gunk, and the non-return valve failing.
You can take the non-return valve out, and blow through the piping.
As above the other problem can be the jets blocked.
Replied by a Guest on topic windscreen washer just aint a-washin no more!
Posted 16 years 8 months ago #3117
jonnocash;3115 wrote: have you tried putting a pin in the jet and have someone opperate the washer?
thanks for that, but i have the peugeot/citroen washers, so atleast a few holes should be working!
Posted 16 years 8 months ago #3118
David Aiketgate;3116 wrote: Known problem areas are the pipes getting full of gunk, and the non-return valve failing.
Thankyou David The White, so that involves me taking stuff apart? honestly, for a sorceror you dont have much up your sleeve do you!:whistle:
Posted 16 years 8 months ago #3120
Lucasdude;3118 wrote: Thankyou David The White, so that involves me taking stuff apart? honestly, for a sorceror you dont have much up your sleeve do you!:whistle:
If you pull the pipe off the non-return valve(circular black thing on the bonnet), you can then try the pump and see where your problem is.
Posted 16 years 8 months ago #3121
David Aiketgate;3120 wrote: If you pull the pipe off the non-return valve(circular black thing on the bonnet), you can then try the pump and see where your problem is.
wilco, thanks mate!
Replied by cjj on topic windscreen washer just aint a-washin no more!
Posted 16 years 8 months ago #3124
Don't look down it while trying it though ;)
Time to create page: 0.401 seconds
