Stuck HT leads (Solved).
Stuck HT leads (Solved). was created by Leigh Ping
Posted 13 years 2 weeks ago #31195
As you may recall, 2 of my ht leads would not budge without making a cracking sound, last time I tried to remove them. So, I left them there, after soaking them with WD40, at that time.
Today, whilst investigating a 'clunk' which may have been coming from an engine mount, I decided to rip the ht leads out. The wire pulled straight out through the rubber housing which stayed in place. After some massive force with pliers and a shattering of the plastic cap, they eventually gave and came out. So, I changed two of them and replaced the spark plugs with iridium ones.
Oh, and the clunk may have been me not bolting the engine cover in place correctly the last time I was under there. As it seems to have gone away now. Fingers crossed.
I won't mention leaving a socket spanner on the engine and driving to the car parts store , only to hear another clunk as it disappeared onto the road via the engine, which was merrily clicking away on 3 cylinders. :oops: lmao.. my boy found it on the way back using his eagle eyed vision. :broon:
Last Edit:13 years 2 weeks ago by Leigh Ping
Last edit: 13 years 2 weeks ago by Leigh Ping.
Replied by David Aiketgate on topic Re: Stuck HT leads (Solved).
Posted 13 years 2 weeks ago #31197
Guess who's getting a Homer award? Doh!...
Replied by Tsleight on topic Re: Stuck HT leads (Solved).
Posted 13 years 2 weeks ago #31203
Hehehe :P :whistle:
Replied by bryan young on topic Re: Stuck HT leads (Solved).
Posted 13 years 2 weeks ago #31218
Leigh Ping wrote: As you may recall, 2 of my ht leads would not budge without making a cracking sound, last time I tried to remove them. So, I left them there, after soaking them with WD40, at that time.
:shrug: a Homer award is a must for this one! :broon: the engine cover is a structural panel and stiffens the body, it is important that all of the bolts are put back and correctly tightened :bust:
Posted 13 years 2 weeks ago #31219
Did you check the engine mounting??? i will post a picture later of a failed engine mounting on a 2003 TF, one bolt sheared first then the second went :bust:
Replied by Leigh Ping on topic Re: Stuck HT leads (Solved).
Posted 13 years 2 weeks ago #31220
bryan young wrote: Did you check the engine mounting??? i will post a picture later of a failed engine mounting on a 2003 TF, one bolt sheared first then the second went :bust:
From what I could see, they were all ok. I'm off for a drive now, as I don't want to wait until my journey to work tomorrow, to see if the clunk has gone.
Posted 13 years 2 weeks ago #31221
I knew I'd seen photos somewhere. :yesnod:
Posted 13 years 2 weeks ago #31224
Just tested the iridium plugs, awesome. Seems the clunk has gone now. Must have been operator error with the engine cover. A blessing really. :broon:
Posted 13 years 2 weeks ago #31225
Yes i posted it ages ago (dim and distant past) still dont know why it happened :shrug: was not loose bolts because they are firmly fixed in the bottom of the mount, but if it was checked at the first notice of "clunking" the first sheared bolt would have been found. Watch this space!!!! :thumbsup:
Posted 13 years 2 weeks ago #31227
The other half took it for a spin after she tired of my requests to do so. :lol:
Definately no bumps or bangs going on now.
Replied by Laz1957 on topic Re: Stuck HT leads (Solved).
Posted 13 years 2 weeks ago #31239
Excellent news :thumbsup:
by Laz1957
Time to create page: 0.524 seconds
