mgtf tf rear brake discs
  • rayb
mgtf tf rear brake discs was created by rayb
Posted 13 years 2 weeks ago #31284
im looking at changing my rear brake discs as they are getting quite worn, but im unsure wether to fit the rear grooved discs or use the plain dics. apart from the obvious is there any other difference in fitting grooved dics. i guess my pads would wear quickly so what pads could i use any input or help would be great
by rayb
Replied by David Aiketgate on topic Re: mgtf tf rear brake discs
Posted 13 years 2 weeks ago #31285
rayb wrote: im looking at changing my rear brake discs as they are getting quite worn, but im unsure wether to fit the rear grooved discs or use the plain dics. apart from the obvious is there any other difference in fitting grooved dics. i guess my pads would wear quickly so what pads could i use any input or help would be great
The grooves are to help dispel heat. Really they help prevent brake fade. Unless you work your brakes really hard or do track work then they are just for looks.
Time to create page: 0.462 seconds
