Annoying rattle on start up
Annoying rattle on start up was created by Tourbillon
Posted 12 years 11 months ago #32835
Guys,
I have an annoying rattle on start up from cold ( Mk1 MGF 1.8). Its not tappets or top end, it sounds like a loose fan rattling against something. The sound only comes when the engine is on fast idle from cold as when its warm, you get nothing. Nothing appears to be loose, but its nagging me that I could drive off one day and leave parts behind on the drive.
Any ideas or something similar with your cars?
Tourbillon
Replied by Luckymarine on topic Re: Annoying rattle on start up
Posted 12 years 11 months ago #32840
I dont know of any of the fans that are programmed to initiate on startup, if its only on fast idle then I think it has to be engine related.
Do you have VVC?
Replied by Rich in Vancouver on topic Re: Annoying rattle on start up
Posted 12 years 11 months ago #32842
Could the exhaust heat shield be slightly loose, enough that it rattles when cold but not when it gets hot and expands a bit?
Replied by Tourbillon on topic Re: Annoying rattle on start up
Posted 12 years 11 months ago #32844
I have a non VVC engine. Rich's comment sounds logical as as soon as the engine is warm there is no noise so Think something may be working itself loose.
Tourbillon
Replied by Dieter on topic Aw: Re: Annoying rattle on start up
Posted 12 years 11 months ago #32845
It's a rather old MGF. I recall there had been some issues with loose pipes for the hydragas system or brake lines at the early cars.
Would recommend to check this at first.
Other is already said. Wherin the engine holder comes in my mind. Worth to check aswell.
Dieter K.
MGF Rep. MGCC DE
[IMG
by Dieter
Posted 12 years 11 months ago #32846
How long does the rattling last for?
Posted 12 years 11 months ago #32849
just until the engine is warm e.g off fast idle
Posted 12 years 11 months ago #32853
I would think it would take a bit longer for any exhaust heatshield to warm up. In the back of my mind I have a niggling thought about lack of oil in the top of the engine as its draining into the sump when left for long periods.
The following user(s) said Thank You: Tourbillon
Replied by David Aiketgate on topic Re: Annoying rattle on start up
Posted 12 years 11 months ago #32868
Luckymarine wrote: I would think it would take a bit longer for any exhaust heatshield to warm up. In the back of my mind I have a niggling thought about lack of oil in the top of the engine as its draining into the sump when left for long periods.
Exhaust manifold shield heats up pretty quickly. :yesnod:
But check the bracket on the oil filler, that can crack and rattle.
Last Edit:12 years 11 months ago by David Aiketgate
Last edit: 12 years 11 months ago by David Aiketgate.
Replied by bryan young on topic Re: Annoying rattle on start up
Posted 12 years 11 months ago #32869
I tend to agree, it could be hydraulic tappets starved of oil, know of a case of blocked pick up in sump that caused this noise. :rant:
Posted 12 years 11 months ago #32879
Thanks Guys, i will have the root around, doesn't sound to me Engine internals, more of some loose ancillary. Oil filler I will give a wiggle as well
Time to create page: 0.538 seconds
