Brake warning light
Brake warning light was created by todds200
Posted 12 years 11 months ago #32908
Hi all,
With the new MOT rules coming into force on 1st jan 2012,i have a small problem with my dash board hand brake/fluid warning light, in that it does not work and has not for 3 years,i have removed the dash and changed the bulb, check the fuses(all of the ones i could see)
The light was working when i got the car because i had a faulty caliper and had that repaired and haven't seen the light on since.Is there a fuse somewhere i am missing.
Any suggestions guys
Does any one no of any garages in cumbria who will blow up my suspension !!
Thanks
Todds
Replied by bryan young on topic Re: Brake warning light
Posted 12 years 11 months ago #32922
todds200 wrote: Hi all,
Thanks
Todds
Depending on the weather, Russell is doing a head gasket for David A on Saturday 17 December have a word with Russell (MG Rover Solutions) about your pump up ??
Replied by David Aiketgate on topic Re: Brake warning light
Posted 12 years 11 months ago #32943
Thanks
Todds
As Bryan says, I have Russell coming up on 17th and he can do pump ups. pm me and I'll give you my address if you want to come over.
Alternatively, I use Peter Allison Auto Repairs, High Moor Farm Garage, How Mill, Brampton. He is brilliant!
01228 670733 or mobile 07786 914667
Warning light problem, it could be the handbrake switch has failed. Sometimes the spring breaks inside the switch(mine did).
Last Edit:12 years 11 months ago by David Aiketgate
Last edit: 12 years 11 months ago by David Aiketgate.
Replied by Dieter on topic Aw: Re: Brake warning light
Posted 12 years 11 months ago #32959
There's a second *switch* inside the expansion tank on the brake master cylinder.
Either the handbrake lever or the level of brake fluid puts the wire to earth and the light to red.
Just screw off the brake fluid cap to check whether the circuit is working in principals.
Dieter K.
MGF Rep. MGCC DE
[IMG
by Dieter
Replied by todds200 on topic Re: Brake warning light
Posted 12 years 11 months ago #33191
Well gents just a up date,
The brake *switch* inside the expansion tank on the brake master cylinder was sticking ,so pushing the plunger a couple of times soon sorted that.
The other problem was the handbrake light switch under the gaiter,This was the wire connector had came of the brake switch(what a pig to get back on)
All working great now,so thanks for the advice.
Regards
Ian
Posted 12 years 11 months ago #33201
todds200 wrote: Well gents just a up date,
Regards
Ian
Nice one Ian, glad to hear you sorted it! :thumbsup:
Posted 12 years 11 months ago #33205
Regards
Ian
Thank you for letting us know the result, two faulty bits causing the same problem :broon: well done sorting it out. :thumbsup:
Replied by talkingcars on topic Re: Brake warning light
Posted 12 years 11 months ago #33209
Glad it is sorted, however I don't think this warning light falls under the MOT, new or old.
Posted 12 years 11 months ago #33213
talkingcars wrote: Glad it is sorted, however I don't think this warning light falls under the MOT, new or old.
A low brake fluid light is part of the test and must work! i agree the handbrake on warning should not :rant: , however if they are one and the same :shrug: i dont know !
Time to create page: 0.523 seconds
