Overheating - Have you checked the fan fuse?
It's vital for all MGF built before YD511059 :omg:
We found this issue back in 2004. Been on a trip in the Alps with 30 cars and my MGF coolant boiled when I parked her at the first pass, stop at Penser Joch.
Thought it's the dreaded head gasket, but after some investigation with help of Tony ( http://www.apttony.co.uk/index_MGF.html ) we found the front fan sticky and the Fuse F2 had blown.
Made the fan rotation again by hand and replaced fuse with a 20Amp type after comparing my fuse panel cover with another friends TF parking beside mine.
http://www.mgfcar.de/event/2004_kaltern/index.htm
http://www.mgfcar.de/event/2004_kaltern/dsc03132.html (ff)
and
http://www.mgfcar.de/fuse/
scroll down to F2
:yesnod:
btw. as another precaution against a blown fuse F2 I put a buzzer parallel to the fuse :oops:
In case my fan gets stuck again and the even the 20Amp blows then the buzzer will make noise.
:yesnod: Uprate the fan fuses to 20 amp. Helps prevent them blowing if the fan is a bit stiff on start up. MGR did it in later TFs.
Replied by David Aiketgate on topic Overheating - Have you checked the fan fuse?
Posted 12 years 11 months ago #33085That's a good idea! :yesnod: Do you have a wiring diagram?Dieter wrote: btw. as another precaution against a blown fuse F2 I put a buzzer parallel to the fuse :oops:
- mgfindevon
- Apprentice MGer
To buy
- 12V buzzer with black and red wires
- crimp sleave M4? (check bolt size be4 you buy, could be M5
- Y- connector
disconnect Battery for save works
Clip off upper cover of the front fuse panel
Bolt off front fuse panel.
Clip off lower cover
Locate the hole in fuse panel (see red arrrow) and lead the black (-) buzzer wire through the hole (from top to bottom.)
Locate brown wire at Fuse # F2 from below (blue arrow) and connect the black buzzer wire with Y-Connector.
Enhance wire if it's to short.
close lower cover. Take care on the black wire.
Put buzzer into fuse panel
Bolt panel back in place
Remove the hex-screw at the plus connection.
Crimp sleave connector to red wire and bolt red wire with sleave to plus
Reconnect battery, synchronize alarm blipper with four times keying a button.
Test:
Put ignition on
Pull fuse F2.
---->Buzzer should come off :woohoo:
Put back Fuse F2
<---Buzzer silent. :woohoo:
If the Buzzer is sounding ongoing ... check wether F2 is broken
looks like a 'how to' to me
Could you just say what you mean by a 'Y connector'? I'm not familiar with that term.
