OVERHEATING MGF
- bryan young
- bryan young
David Aiketgate wrote: This connects rather nicely with this new How to :yesnod:
Could to tack something onto the end please, i recall that you have a picture of the position of the AAT sensor on the panel above the inlet manifold, and the description for testing if faulty i.e. disconnect and bridge terminals and fan (In duct) should run!! Thank you.
The blown fuse buzzer idea is an absolutely great idea, Deiter shoul get two gold awards for that :thumbsup:
I'd definitely give an award, :thumbsup: ...if the medals award gizmo was working :nonod: . Simon's trying to figure out why it isn't. :yesnod:
- bryan young
Yes that is the photo. :thumbsup:
In my oppion that fan is only for cooling down the fuel lines. Nothing proves relations of the rear fan to significant engine temperature droping. Also from physical point of view it is impossible to change heat of a 150kg aluminium block with the tiny fart from this fan
:bust:
From what I heard of it's still the engine bay temperature, but measured by the ECU.
I woiuld have investigated the truth myself if I'd own a TF :broon:
Paul, nope, that's the German bean counter :silly:
The *Engine Overheat* issue does a quite panic reaction at MG (F/TF) owners.
As for the trouble with boiling fuel see for search term *Vapor lock* with Mr google.
David, article looks fine now ... :thumbsup:
