Raining in my boot
My TF has been quietly loosing a little coolant, nothing wrong with the oil, no increase in the oil level, coolant is nice and clear but a few days ago I noticed some condensation on the underside of the bootlid. I wiped it off and then checked again this morning, after leaving the car running on the drive to defrost and the condensation was back. After driving to work, it had got a fair bit worse, even as far as dripping down onto my laptop bag in the boot.
Am I right thinking it's probably the expansion cap venting too early and the steam condensing on the cold bootlid? Or is it coming from somewhere more serious?
Back with front wheel drive and 181HP at the wheels
Get a new cap anyway as they're cheap, but get a 'proper' one from the likes of Mike Satur.
Have you confirmed it with the kitchen paper?:shrug:andy1970h wrote: The one that's failed is a proper one from Mike Satur but I've ordered another one anyway.
David Aiketgate wrote: The easy way to check is to wrap some kitchen roll around the expansion tank neck, if it goes pink(or other appropriate colour, you've got your answer.
That is a top tip :broon: :broon: :broon:
There are several coolant pipes on an MGF but some crop up regularly as leak culprits, again the archives have a lot of info.
