New Member - Info Required
New Member - Info Required was created by Quayside282
Posted 12 years 10 months ago #37053
Hi All,
just joined the site and as my car is in hibernation till the warm(ish!) weather arrives I'd like some info on what to do next?
I've got a 2003 TF 1.8 135 with 39k on the clock. Its NOT had the HG done and was wondering whether to put it in and get it sorted or leave it until 'something' happens? Whats your guidence? I've heard the drilling a small hole in the thermostat is reccommended, any ideas on this?
Replied by rayb on topic Re: New Member - Info Required
Posted 12 years 10 months ago #37054
i would personally leave it till it does show signs of hgf. not all mgf/tfs suffer from HGF ive known cars still on there original head gasket at 70,000 miles as long as you check your coolant on a regular basis check for leaks etc. keep the money in the bank and enjoy the car
by rayb
Replied by David Aiketgate on topic Re: New Member - Info Required
Posted 12 years 10 months ago #37056
:welcome2:
If it's not broken, why fix it?
Do you have any coolant loss?
We have two forum sponsors who are mobile mechanics and will replace the head gasket very reasonably, if it does go.
Drilling the thermostat is often tried, not often successfully. Replacing the thermostat with a Pressure relief thermostat setup is a better answer.
Replied by Rich in Vancouver on topic Re: New Member - Info Required
Posted 12 years 10 months ago #37081
I agree with David.
As they say in North America..."If it ain't broke, don't fix it!"
By the way, WELCOME! :thumbsup:
Replied by Leigh Ping on topic Re: New Member - Info Required
Posted 12 years 10 months ago #37097
Hello and welcome. :)
Replied by bryan young on topic Re: New Member - Info Required
Posted 12 years 10 months ago #37114
My 1996 MGF is approaching 60,000 and has not suffered HGF, spoke to Russell about doing it whilst it was undergoing other work and off the road and he said the same thing "dont bother until it gives problems" but i am going to fit a coolant level sensor kit and the later thermostat set up.
AND Welcome to the T Bar :woohoo:
Replied by Luckymarine on topic Re: New Member - Info Required
Posted 12 years 10 months ago #37115
Keep the money in the ISA till something happens.
Head gasket failure is usually a slow process, its a very rare occasion your car will just stop suddenly in the middle of the road with no prior warnings. So you'd be able to get your car home.
The new thermostats come with a jiggle valve incorporated into it.
Last Edit:12 years 10 months ago by Luckymarine
Last edit: 12 years 10 months ago by Luckymarine.
Time to create page: 0.492 seconds
