Tracking
Replied by Laz1957 on topic Re: Tracking
Posted 12 years 10 months ago #37174
My Mpi F has none of the extras fitted, so no EPAS or passenger airbag.
Got used to the lack of power steering and, if there had been a passanger airbag, I wouldn't have been able to fit my bluetooth and ipod adapter plus ipod for my Pioneer AVIC :thumbsup:
Last Edit:12 years 10 months ago by Laz1957
Last edit: 12 years 10 months ago by Laz1957.
Replied by Leigh Ping on topic Re: Tracking
Posted 12 years 10 months ago #37190
WE HAVE EPAS RECTIFICATION IN THE HOW TO GUIDES. :blink:
Have a look some day you guys. :ohmy:
Apart from David, as he wrote it. :lol:
Last Edit:12 years 10 months ago by Leigh Ping
Last edit: 12 years 10 months ago by Leigh Ping.
The following user(s) said Thank You: bryan young, leemcmini
Replied by Rich in Vancouver on topic Re: Tracking
Posted 12 years 10 months ago #37213
I have another option combination in my 1996 MPi. No EPAS but I do have the passenger airbag.
My wife is happy that I do as she is the passenger in a RHD car on LHD roads so she is on the
head-on impact side of the car! :ohmy:
I have been considering installing EPAS just to get a tilt column as part of the deal.
Back to the subject of this thread...I agree that there is a reason that the rear tire is bald. It would certainly be
worthwhile to check the rear suspension carefully. Worn bushings or ball joints could be causing the problem.
You could find a matching set of part worn tires on E-bay quite cheap. That would be a better solution than buying
one new tire.
Last Edit:12 years 10 months ago by Rich in Vancouver
Last edit: 12 years 10 months ago by Rich in Vancouver.
Replied by mowog73 on topic Re: Tracking
Posted 12 years 10 months ago #37240
Rich,
A tilting steering wheel must have been a later option because my 1995 MPi has EPAS but it does not tilt..
[size=10pt]Mark[/size]
95 MGF
by mowog73
Replied by bryan young on topic Re: Tracking
Posted 12 years 10 months ago #37259
mowog73 wrote: Rich,
I understand there are three steering columns :-?
1. Non EPAS
2. the EPAS one fitted to the Fs originally and
3. A later one with EPAS and Tilt, think fitted to the TF
Daz at Pocket Motors in Poole will advise which one his conversion Kit uses ?
I vaguely recall reading somewhere that the very early Fs came out of the factory with a passenger airbag as standard!! then they dropped it and made it an optional extra. :omg:
Replied by leemcmini on topic Re: Tracking
Posted 12 years 10 months ago #37260
ta for all advice mines got the tilt steering wheel, i think that came in on the mk2 f then tf's
my car has got good tyres on the fronts a matching set and one new tyre to the rear and a bold one i think they just changed the one rear tyre before, the wear looks nice and even, and the car sits well slightly lower than my old F but i think is because this one has the 16" wheels. im hoping i can match the tread on rear tyres as it seems a shame to change the one rear when its in good nick :thumbsup:
Posted 12 years 10 months ago #37261
The ride height will be the same for the 16" wheels as they are the same overall diameter as the 15" ones because of the lower profile tyres (40 & 45 profile) if you go to 17" wheels the profile goes to 30/35. If you car has been lowered with lowering pins the height will be 20mm lower. Measure from the centre of the wheel to the wheelarch and let us know what it is in millimeteres.
It is important that you get exactly the same rear tyre as the rest of the matching set, otherwise the handling will suffer. you did not say what make of tyres were on, but if they are Goodyear Eagle GSD2 ? they have been discontinued but can still be obtained from the MGF Centre in Wolverhampton. Do not fit Goodyear GSD3's they make the car very unstable, bit like driving on ice.
Have you checked all of the other suspension items suggested and what is the wheel bearing like on the side with the bald tyre?
Last Edit:12 years 10 months ago by bryan young
Last edit: 12 years 10 months ago by PQD44.
  • Visitor
  • Visitor
Replied by a Guest on topic Re: Tracking
Posted 12 years 10 months ago #37262
1. Non EPAS
Mk2 Fs have tilting columns too
Replied by Mr Forgetful on topic Re: Tracking
Posted 12 years 10 months ago #37306
Perhaps one rear tyre was changed for an "unrepairable" puncture - thus giving one "new" one and the original other bald one? Times is 'ard and not all can afford to replace two tyres at one go (although one should if one could - poetic isn't it?) B)
Time to create page: 0.562 seconds
