MGF Steering Rack
MGF went for her Mot today and passed but got 2 advisories with rear tyres on the limit and play in the steering rack on the passenger side.
Is there any adjustment on the drum sticks or they a full replacement and if so where is the best place to either get a new one or reconditioned,bit unsure about buy a rack of ebay because i dont what im getting until ive got it delivered and has any one removed and replaced one.
Shes a 1999 Mk 2 MGF
any advice would be great.
Had to give her a good blast to get her through the emissions,Just scrapped it.
But happy with the result.
Just ordered 2 toyos from camskill
regards
todds
How many miles has she done?
Specifying one side would suggest it's the track rod end.
- bryan young
David Aiketgate wrote: Are you sure it's play in the rack? Play in the rack would show normally both sides equally.
I totally agree with that :thumbsup: it does seem strange to say that one end is worn. can you check it without removing the gaiter first??
David, just changed both track rod ends in november,if i move the wheel in and out,there is a bit of play inside the steering gaiter and see and feel the drum stick moving but no movement on the steering wheel
regards
todds
You can get them replaced but it's a specialist job. You be better off getting a good secondhand one from MGFnTFBits. It'll be cheaper.
I got a track rod replaced on a Nissan steering rack and that was £75.
to change the rack you have to drop the sub frame down so easier to replace the arm
mad about cars and bikes
if it aint broke dont fix it
Does anyone no if a mk1 steering rack is the same as the mk2
regards
todds
Thanks for the brilliant offer for the steering rack but a friend of mine has a TF rack that i can have and will replace when the weather warms up.
Can't believe how generous the MGF/TF community is.
Regards
Todds
