MGF Steering Rack
MGF Steering Rack was created by todds200
Posted 12 years 10 months ago #37402
Hi All,
MGF went for her Mot today and passed but got 2 advisories with rear tyres on the limit and play in the steering rack on the passenger side.
Is there any adjustment on the drum sticks or they a full replacement and if so where is the best place to either get a new one or reconditioned,bit unsure about buy a rack of ebay because i dont what im getting until ive got it delivered and has any one removed and replaced one.
Shes a 1999 Mk 2 MGF
any advice would be great.
Had to give her a good blast to get her through the emissions,Just scrapped it.
But happy with the result.
Just ordered 2 toyos from camskill
regards
todds
Replied by Red Devil on topic Re: MGF Steering Rack
Posted 12 years 10 months ago #37404
Hi todds, that does not seem at all bad :thumbsup:
How many miles has she done?
Replied by David Aiketgate on topic Re: MGF Steering Rack
Posted 12 years 10 months ago #37406
Are you sure it's play in the rack? Play in the rack would show normally both sides equally.
Specifying one side would suggest it's the track rod end.
Last Edit:12 years 10 months ago by David Aiketgate
Last edit: 12 years 10 months ago by David Aiketgate.
Replied by bryan young on topic Re: MGF Steering Rack
Posted 12 years 10 months ago #37414
David Aiketgate wrote: Are you sure it's play in the rack? Play in the rack would show normally both sides equally.
I totally agree with that :thumbsup: it does seem strange to say that one end is worn. can you check it without removing the gaiter first??
Replied by todds200 on topic Re: MGF Steering Rack
Posted 12 years 10 months ago #37417
RD she done 84 thou
David, just changed both track rod ends in november,if i move the wheel in and out,there is a bit of play inside the steering gaiter and see and feel the drum stick moving but no movement on the steering wheel
regards
todds
Posted 12 years 10 months ago #37422
Ah so its play on the inner end of the track rod. :yesnod:
You can get them replaced but it's a specialist job. You be better off getting a good secondhand one from MGFnTFBits. It'll be cheaper.
I got a track rod replaced on a Nissan steering rack and that was £75.
Replied by MGF MARK on topic Re: MGF Steering Rack
Posted 12 years 10 months ago #37431
track rods dont cost the earth
to change the rack you have to drop the sub frame down so easier to replace the arm
mad about cars and bikes :)
  • birks
  • Loves going topless!!!
Replied by birks on topic Re: MGF Steering Rack
Posted 12 years 10 months ago #37434
Not sure if it's the same part, but we have the steering rack off George (Mk 1 MGF vvc 1997) that you can have for delivery charge/pick up if it's any help :-?
by birks
Posted 12 years 10 months ago #37444
Thanks very much,
Does anyone no if a mk1 steering rack is the same as the mk2
regards
todds
Posted 12 years 10 months ago #37445
should be the same also peeps put the tf rack on as it lessens the number of turns from full lock to full lock
  • birks
Posted 12 years 10 months ago #37450
It certainly fits, but may be different...i believe one is a 'yellow band' and one is a 'red? band'...the TF rack is supposed to be superior, but I can't say I've noticed much difference between them (I've owned a Mk I, Mk II and a TF!)
by birks
Posted 12 years 10 months ago #37467
Birks,
Thanks for the brilliant offer for the steering rack but a friend of mine has a TF rack that i can have and will replace when the weather warms up.
Can't believe how generous the MGF/TF community is.
Regards
Todds
Last Edit:12 years 10 months ago by todds200
Time to create page: 0.533 seconds
