tf door handle and surround
hi guys i have a problem with my drivers door handle, :bang: any help would be much appreciated...i have found that that one of the "self tapping screws" has pulled out of its plastic holder and now doesn't hold the handle mechanism solidly in the door .I have removed said handle and it looks like i will have to buy a new complete unit, my question is can it be repaired ?? or does any other rover door handle fit ?? thanks for reading ....phil
by yamyam75
- Tourbillon
Has where the screws attached stripped threads in the plastic?
by Tourbillon
thanks for the reply Tourbillion yes its damaged ( for want of better words) the plastic post which the screws fit to and pulled the thread clean out !
by yamyam75
Replied by David Aiketgate on topic Re: tf door handle and surround
Posted 12 years 11 months ago #39077
Do you have a photo of the problem?
You might be able to use a nut-sert in place of the stripped thread.:shrug:
Last Edit:12 years 11 months ago
by yamyam75
Last edit: 12 years 11 months ago by David Aiketgate.
- Tourbillon
Is this what you are looking at?
on this image you can see the left post with thread curling out. (ignore arrows)
if so then you could rebuild the post with araldite, leave overnight put in small pilot hole and cut a new thread with the self tapper.
by Tourbillon
Last edit: 12 years 11 months ago by Tourbillon.
by yamyam75
- Tourbillon
yep, looks pretty knackered. Still might be worth a fix if you can get a small jubilee clip around the post to pull it all together whist the glue hardens. Alternative is ordering a salvage part, but to get a colour match could take a while.
by Tourbillon
thank you for that but its all just fell apart it was holding on by a thread so looks like its off to the scrappers ....oh the joy ....many thanks for the advice
by yamyam75
- Tourbillon
call MGF and TFbits ( see glovebox) they will sort you out.
Tourbillon
Tourbillon
by Tourbillon
- bryan young
Replied by bryan young on topic Re: tf door handle and surround
Posted 12 years 11 months ago #39086
Yes it does look knackered, not sure that the araldite will work either, it is an epoxy resin and the handle moulding is likeley to be ABS (the post is also split to allow the self tapper to cut a thread and have some expansion. the plastic ages and hardens with time and snaps. I have replaced handles on both sides on my Honda Accord the plastic Tit that activates the lock just snapped off, its about 6mm x 12mm and sheared clean through. Mine are colour coded and cost £60 each.
Try Darryl at Pocket Motors or mgfntfbitz for one.
by bryan young
Time to create page: 0.539 seconds
