Coolant leak - somewhere else to check
Coolant leak - somewhere else to check was created by David Aiketgate
Posted 12 years 9 months ago #41842I checked, and the level had dropped by 1.5 cm.
I checked the usual culprits, but all was dry.
Then I noticed a wet pink stain below the expansion tank(on the hydragas sphere)
The underside of the expansion tank was wet, and when I removed the tank I could see that the spring clamp(no 18 below) on the hose(no 6 below) that enters the bottom of the tank was loose enough that I could rotate the pipe on the spigot.
I replaced it with a new jubilee clip and leak fixed. :yesnod:
Replied by Humphrey on topic Re: Coolant leak - somewhere else to check
Posted 12 years 9 months ago #41843Brings us oot in a cold sweat. Glad it was so simple! You will sleep ok tonite
John
'I started off with nuthin and still got most of it left!'
You know, I spent a fortune on deodorant before I realised
that people didn't like me anyway!
- bryan young
Replied by bryan young on topic Re: Coolant leak - somewhere else to check
Posted 12 years 9 months ago #41847AND :woohoo: horray for the coolant alarm, everyone should have one. :slapme:
Replied by mowog73 on topic Re: Coolant leak - somewhere else to check
Posted 12 years 9 months ago #41862[size=10pt]Mark[/size]
95 MGF
- pendle lass
Replied by pendle lass on topic Re: Coolant leak - somewhere else to check
Posted 12 years 9 months ago #41867Please Log in or Create an account to join the conversation.
- bryan young
Posted 12 years 9 months ago #41869mowog73 wrote: Thanks for this information David. My next task, once the timing belt is changed, is to install the B&G coolant level alarm kit I bought at Christmas time.
That should be an easy job compared to the engine mounts (hopefully) there is a good "how to fit the B&G one " in the March MG Enthusiast by F owner Jim Jupp, if you dont get the mag, i can scan it and email it to you ~ just PM me you email address please. :yesnod:
Replied by David Aiketgate on topic Re: Coolant leak - somewhere else to check
Posted 12 years 9 months ago #41873David
Posted 12 years 9 months ago #41961After re-tightening the jubilee clip, when I ran the car up to temperature...drip drip drip...
So I took the expansion tank off the car and examined it closely.
It was leaking here:-
I also found a lot of minute cracks in the bottom of the tank, ooh err!
New tank coming soon.
- bryan young
Posted 12 years 9 months ago #41968Please Log in or Create an account to join the conversation.
Posted 12 years 9 months ago #41973Worth checking yours, you other peeps out there. At least a low coolant alarm would warn you but a fractured tank could empty very quickly.
- bryan young
Posted 12 years 9 months ago #42007David Aiketgate wrote: I'm assuming it's the original tank so at least 11 years old, subject to heat stresses, and Ethylene Glycol and other chemicals. so it's had a hard life.
Thinking about it further that could be the reason why some owners loose a small amount, but dont have any signs of a leak :slapme: its dripping slowly and drying off whilst the engine is running, then leaking again when the system gets back up to pressure.
For the small amount of hassle it is worth a check.
Posted 12 years 9 months ago #42040[size=10pt]Mark[/size]
95 MGF
