High Level Brake Light
Is this light replaceable or is it time for a new unit all together?
bensewell wrote: Mines not working. Was going to sort it while I was having a good time with the glow fuses but was scared of popping it off and causing some damage.
Check that its not just a faulty wire or connection to make sure it really is kaput. The light is made up of LEDs so it could just be a question of replacing one or two. Most people tend to buy a new unit.
The TF is more difficult to take apart and uses leds.
Check that the light is actually getting a live feed from the brakelights before assuming the unit is defective.
thats the most common fault on an f and tf
mad about cars and bikes
if it aint broke dont fix it
If I can find a pic I will post it.
Here it is
- a Guest
- Visitor
The harness gets split and the wires frayed from the boot action, if its not that still tape it up after ensuring they are all working correctly
I will try this later. I'm just writing up a how-to on some of the things i've been getting up to recently.
Yesterday was new heater knobs, swapping oil + clock rings round.
Today was glow-fuses, well some of them
Tomorrow is fix your brake light, Look at the Engine Management Light, fit roof band assister things and maybe as a special request by softly softly the aqua aerobic foam thing.
And for all those folk who remembered my mishap involving locking keys in the boot I've a document that I think i need to email round a few of the admins.
When I'm tinkering with the TF know I always make sure the keys are around my neck on a chain.
funnily enough vauxhall cabby suffer the same problem
ben where are you based ??
- a Guest
- Visitor
This is my thread in '3C MG' :-
http://www.3counties-mg.co.uk/forums/viewtopic.php?f=5&t=1678
MGF MARK wrote: yep extend the wires soit creates a loop so does not strain the main harness so lasts longer
ben where are you based ??[/quote
I live 20 mins away from Barnsley, Rotherham, Sheffield, Wakefield and Doncaster. Its a mile away from Mike Satur's
