Air filter installation.
Air filter installation. was created by Ozzy
Posted 12 years 7 months ago #49322
hey guys
few people asked me to pop up my experience of the £40 induction kit from ebay:
Forced Induction Cold Air Feed pipe Kit Cone Ram Filter + 3inch Duct Flexipipe
Completed
i also purchased a reducing elbow in silicon from my local car tuning shop for £30...
so here is my quick guide to the install:
1. firstly, start with taking the parcel shelf out, and insulating foam, lift the rear of the roof (for better access), and undo the 10/12 10mm bolts holding the engine cover down...
2. start to remove the original airbox... this is done with 4 clips holding the top down, just unclip all 4 and remove the top of the filter housing...
as part of this process unscrew the juberlee clip on the throttle body:
then remove the inlet hose, and upper filter housing as one unit...
3. remove the filter from the air box that is now exposed:
as you can see mine was due a change...
4. remove the lower airbox housing, this was just a case of pulling towards the engine block and lifting for me, there may have meant to have been a securing screw, but mine did not have one...
removal is a bit of a squeeze, but do-able...
this leaves a nice big gap for the new filter to go into...
5. install the flexi hose from the side pod to the bottom of the airfilter, i did this by taking out the 2 retaining screws (philips head) in the side pod cover, and then running the flex down to the side pod from above...
and connect to the filter with the supplied juberlee clip...
6. i purchased a silicon elbow in black to link my filter to the throttle body...
initially i put this on the TB first, but that turned out to be a mistake as i couldnt do up the 2nd juberlee clip on the filter, so then put it on the filter and put them both on the TB
i installed this on the filter first, then put the 2 in place...
then it is a case of ensuring everything is done up tightly, not pinching, and putting it all back together....
Oz.
Last Edit:12 years 7 months ago by Ozzy
Last edit: 12 years 7 months ago by Leigh Ping. Reason: Ebay screenshot in case the Ad goes.
The following user(s) said Thank You: Leigh Ping, jac114, KentJohn
Replied by jac114 on topic Re: ebay air filter... installation as promised...
Posted 12 years 7 months ago #49324
o.k so seeing you do that has thrown up the question as to why so many people talk about cutting up the resinator box to fit an induction kit ???? also how does the car sound and does it honestly feel any better to drive ?
by jac114
  • Visitor
  • Visitor
Replied by a Guest on topic Re: ebay air filter... installation as promised...
Posted 12 years 7 months ago #49325
Nice job, looks just like mine ;)
  • tui
  • Penelope Pitstop
Replied by tui on topic Re: ebay air filter... installation as promised...
Posted 12 years 7 months ago #49326
You make it look so simple!
As Jac said, it would be nice to hear how it sounds, maybe a video?
-=Visit my Website!=-
by tui
Replied by Ozzy on topic Re: ebay air filter... installation as promised...
Posted 12 years 7 months ago #49336
Took about 50 mins start to finish...
Almost no difference to drive, pulls a bit better over 90/100mph...
Fuel economy will let you know...
But had to do something as the original pipe that the air box sucks from had come off and so the car would get VERY high intake temps in heavy traffic (60-80c on occasions!!!)
Sounds nicer on throttle under load now though :)
I'm happy with it. Will do a video at some point... Probably a bit pointless in my case though as my TT exhaust is 110db at 5500rpm!!!
It's insanely loud already... Got odd looks this evening from 4 chaps in a Ferrari FF in hindhead tunnel who couldn't hear their own v12 over my mgf :bust:
Oz
Last edit: 12 years 7 months ago by Ozzy.
Replied by David Aiketgate on topic Re: ebay air filter... installation as promised...
Posted 12 years 7 months ago #49384
jac114 wrote: o.k so seeing you do that has thrown up the question as to why so many people talk about cutting up the resinator box to fit an induction kit ???? also how does the car sound and does it honestly feel any better to drive ?
i believe this is a mk2 airbox. It is bigger than the mk1 and doesn't have the resonator box below it as the mk1 does.
Posted 12 years 7 months ago #49389
yes, sorry, car is MY2001... last year of the F...
by Ozzy
Replied by Leigh Ping on topic Re: Air filter installation.
Posted 12 years 7 months ago #49401
Now in the 'how to's. Superb mod and guide. Cheers Ozzy. :broon:
Air filter upgrade installation - Air filter upgrade installation guide and original airbox removal.
Replied by bryan young on topic Re: ebay air filter... installation as promised...
Posted 12 years 7 months ago #49402
That is correct, mine is a Mk 1 airbox with the resonator box below which is fixed into position with three bolts throught the nearside inner wheel arch. Mind you, i undid the bolts on mine and nothing moved, so put that job lower down the ever growing list :slapme:
Replied by Ozzy on topic Re: Air filter installation.
Posted 12 years 7 months ago #49431
Leigh Ping wrote: Now in the 'how to's. Superb mod and guide. Cheers Ozzy. :broon:
cool, glad i could contribute something for a change :broon:
by Ozzy
Replied by Laz1957 on topic Re: Air filter installation.
Posted 12 years 7 months ago #49781
Whew - glad that was the later airbox - I would have hated to have wasted 2 days with a Dremel for no reason :lol:
by Laz1957
Replied by tikkathreebarrels on topic Re: Air filter installation.
Posted 12 years 7 months ago #49785
Explain please?
Have you been modding yours and before I get much further with mine (I've got a 52mm TB waiting to be fitted, I've removed most of the rigid pipe which runs within the airbox and I'm planning to trunk it to the n/s duct). Thanks
Time to create page: 1.412 seconds
