Air filter installation.
i also purchased a reducing elbow in silicon from my local car tuning shop for £30...
so here is my quick guide to the install:
1. firstly, start with taking the parcel shelf out, and insulating foam, lift the rear of the roof (for better access), and undo the 10/12 10mm bolts holding the engine cover down...
2. start to remove the original airbox... this is done with 4 clips holding the top down, just unclip all 4 and remove the top of the filter housing...
as part of this process unscrew the juberlee clip on the throttle body:
then remove the inlet hose, and upper filter housing as one unit...
3. remove the filter from the air box that is now exposed:
as you can see mine was due a change...
4. remove the lower airbox housing, this was just a case of pulling towards the engine block and lifting for me, there may have meant to have been a securing screw, but mine did not have one...
removal is a bit of a squeeze, but do-able...
this leaves a nice big gap for the new filter to go into...
5. install the flexi hose from the side pod to the bottom of the airfilter, i did this by taking out the 2 retaining screws (philips head) in the side pod cover, and then running the flex down to the side pod from above...
and connect to the filter with the supplied juberlee clip...
6. i purchased a silicon elbow in black to link my filter to the throttle body...
initially i put this on the TB first, but that turned out to be a mistake as i couldnt do up the 2nd juberlee clip on the filter, so then put it on the filter and put them both on the TB
i installed this on the filter first, then put the 2 in place...
then it is a case of ensuring everything is done up tightly, not pinching, and putting it all back together....
Oz.
Replied by jac114 on topic Re: ebay air filter... installation as promised...
Posted 12 years 6 months ago #49324Please Log in or Create an account to join the conversation.
- a Guest
- Visitor
Replied by a Guest on topic Re: ebay air filter... installation as promised...
Posted 12 years 6 months ago #49325Please Log in or Create an account to join the conversation.
Replied by tui on topic Re: ebay air filter... installation as promised...
Posted 12 years 6 months ago #49326As Jac said, it would be nice to hear how it sounds, maybe a video?
Replied by Ozzy on topic Re: ebay air filter... installation as promised...
Posted 12 years 6 months ago #49336Almost no difference to drive, pulls a bit better over 90/100mph...
Fuel economy will let you know...
But had to do something as the original pipe that the air box sucks from had come off and so the car would get VERY high intake temps in heavy traffic (60-80c on occasions!!!)
Sounds nicer on throttle under load now though
I'm happy with it. Will do a video at some point... Probably a bit pointless in my case though as my TT exhaust is 110db at 5500rpm!!!
It's insanely loud already... Got odd looks this evening from 4 chaps in a Ferrari FF in hindhead tunnel who couldn't hear their own v12 over my mgf :bust:
Oz
- Online
Replied by David Aiketgate on topic Re: ebay air filter... installation as promised...
Posted 12 years 6 months ago #49384jac114 wrote: o.k so seeing you do that has thrown up the question as to why so many people talk about cutting up the resinator box to fit an induction kit ???? also how does the car sound and does it honestly feel any better to drive ?
i believe this is a mk2 airbox. It is bigger than the mk1 and doesn't have the resonator box below it as the mk1 does.
yes, sorry, car is MY2001... last year of the F...
- Leigh Ping
- Online
Air filter upgrade installation - Air filter upgrade installation guide and original airbox removal.
- bryan young
Replied by bryan young on topic Re: ebay air filter... installation as promised...
That is correct, mine is a Mk 1 airbox with the resonator box below which is fixed into position with three bolts throught the nearside inner wheel arch. Mind you, i undid the bolts on mine and nothing moved, so put that job lower down the ever growing list :slapme:
Leigh Ping wrote: Now in the 'how to's. Superb mod and guide. Cheers Ozzy. :broon:
cool, glad i could contribute something for a change :broon:
- tikkathreebarrels
- Apprentice MGer
Replied by tikkathreebarrels on topic Re: Air filter installation.
Posted 12 years 6 months ago #49785Have you been modding yours and before I get much further with mine (I've got a 52mm TB waiting to be fitted, I've removed most of the rigid pipe which runs within the airbox and I'm planning to trunk it to the n/s duct). Thanks
