Start of AP rear brake conversion.
Start of AP rear brake conversion. was created by cjj
Posted 12 years 5 months ago #51924
Well, I started playing today with an old rear subframe I have in the garden, complete with hubs etc, to see if the APs will fit.
If it wasn't for the handbrake problem it would be one of the easiest conversions ever.
Putting the handbrake part to one side at the minute, the only major problem is the fitting point for the calipers. The holes are too small for the bolts and are slightly closer together.
I reckon that they could be eased out to the correct size and in the correct direction using just a file. Might take a bit of elbow grease, but I have some in the garage. ;)
The 304mm vented discs came off the old front subframe and mounted correctly on the rear hub.
One of my main worries was that the mounting lugs wouldn't put the caliper central on the disc. But......it is a perfect fit.
So, apart from adjusting the mounting holes slightly, it is all just bolt on.
Here's some pics.
Replied by David Aiketgate on topic Re: Start of AP rear brake conversion.
Posted 12 years 5 months ago #51930
Interesting, could you mount the standard calliper forward, just for the handbrake?
Replied by Laz1957 on topic Re: Start of AP rear brake conversion.
Posted 12 years 5 months ago #52520
Is there a solution to the hand brake problem though?
by Laz1957
  • Visitor
  • Visitor
Replied by a Guest on topic Re: Start of AP rear brake conversion.
Posted 12 years 5 months ago #52522
we did fit athe 4 pot to the rear of one of our mgfs.its easy to make the holes larger and it fits on no problem.but it then means you have the same size brakes all round.the car was bloody dangerous.hard braking and the rear end stepped out,and if you are in damp conditions it will get into a skid that you cant recover from.the abs is designed to work with in the manufactures spec.its a nice idea in princeable but it wont work.if you can fit the larger discs and get bigger pins for the rear brakes already fitted and get a braket made that will work.we are trying that in a few weeks.I have two mgfs that i try different things on, the third one was written off in the wet with the idea you are trying to do.And i have race car experiance
Replied by cjj on topic Re: Start of AP rear brake conversion.
Posted 12 years 5 months ago #52537
The ABS should kick in at the sign of any wheel locking up so I don't see how the skid would be a problem. I would think the problem would be the ABS coming in all the time. ;) Did yours have ABS?
While I see the ABS as a safety blanket, don't get the impression I will be relying on it, I won't be, as the brakes will be set up properly for the car.
Did you fit a brake bias valve and set it up for correct front/rear bias?
I would never run with a 50/50 bias, but I will be looking into what is the ideal bias for a small mid engined RWD car. I would think around 60/40 would be the best.
You could probably set it up to have the same rear braking as the standards if you wanted to.
The main reason for doing this is to get rid of the feeble single pot calipers that don't work very well when new and then get progressively worse over a short period. They really are dire. If the handbrake mechanism doesn't seize the caliper will. I want reliability.
As for the handbrake.
I am looking at fitting spot calipers from HiSpec which give the handbrake function in a seperate caliper.
http://www.hispecbrake.co.uk/Spot.html
Last Edit:12 years 5 months ago by cjj
Last edit: 12 years 5 months ago by cjj.
Replied by Leigh Ping on topic Re: Start of AP rear brake conversion.
Posted 12 years 5 months ago #52539
cjj wrote: I am looking at fitting spot calipers from HiSpec which give the handbrake function in a seperate caliper.
That's a great solution. I never realised such a thing existed.
Posted 12 years 5 months ago #52542
Neither did I until recently.
Posted 12 years 5 months ago #52562
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /var/www/vhosts/the-t-bar.com/httpdocs/libraries/kunena/src/BBCode/KunenaBBCode.php on line 304. Please enable debug mode for more information.
  • Visitor
  • Visitor
Posted 12 years 5 months ago #52576
brake bias valves are used all the time on track cars and if set up correctly work,but they need to be set up correctly
Posted 12 years 5 months ago #52585
I will be taking it to a motorsport place to have it set up.
Replied by Rich in Vancouver on topic Re: Start of AP rear brake conversion.
Posted 12 years 5 months ago #52591
The Wilwood valves are top quality. They are all very simple devices, basically a fluid choke.
You need a large expanse of pavement to set them up (or a very wide empty road)
It is as simple as getting up to 50MPH applying the brakes firmly and seeing which end locks up first.
Adjust valve as required and repeat until you are happy with the results. Repeat procedure in the wet
and make note of the settings, both wet and dry.
Of course this can also be done on a brake test rig, but that's not nearly as much fun.
Replied by Daniel-Cook on topic Start of AP rear brake conversion.
Posted 12 years 5 months ago #52632
For your handbrake just use a rear line lock! There only £30 from trident or demon tweeks! We use them on our road sport race cars!!
Time to create page: 0.522 seconds
