De-Icing
I've also noticed the steering wheel makes my paws really cold. (Wuss) Does anyone know of a nice looking steering wheel cover that won't look stupid?
Have you thought about gloves instead of a steering wheel cover?
CJJ;5844 wrote: I don't de-ice. Not sure what effect the chemicals will have on the plastic long term. Really, the best answer is to fit a glass rear screen with heater element.
I'm after a glass rear screen, but at the moment I can't afford to eat! Plus, every time I get Flopsy a present, she has a sick...
I did think about gloves, but I'm a smoker and I would set fire to myself!
Looks like I'll have to stick with not being able to see out the back!
Also try a set of fingerless gloves for keeping the paws warm.:snow:
CJJ;5861 wrote: You get used to it. I drive vans anyway, so not a biggy for me.
I've never driven anything without a back window, so it seems bizarre to me!
David Aiketgate;5862 wrote: Try warm water poured over the outside of the rear window.
Plan and a half! I think I may have some fingerless gloves somewhere. I thought about trying water on the window, but I didn't know if it would crack the plastic because of the change in temperature.
phil-hex;5882 wrote: as long as the water is just luke warm it shouldn't be a problem
I'll give it a go in the morning if I'm brave enough!
Reaper;5900 wrote: Dont bother with the rear screen, just use your mirrors. The plastic is so brittle when cold i wouldnt risk it.
I really hate not seeing out the back, it's all wierd!
mgf_matt;5905 wrote: Hardtop? lol
Hard top?! Are you nuts! If I could afford a hard top, I'd buy a glass rear screen and spend the rest on me! :yesnod:
Alias;5907 wrote: Hard top?! Are you nuts! If I could afford a hard top, I'd buy a glass rear screen and spend the rest on me! :yesnod:
I like your thinking there - good answer:yesnod:
MG TF LE500 27 of 500
