Re: MG Clock running slow (Solved).
MG Clock running slow (Solved). was created by Leigh Ping
Posted 12 years 5 months ago #60927
My clock was running very slow, losing hours and hours daily. At first I thought it was my leaking battery, which I changed. That wasn't the problem though.
With a bit of googling I was able to find a remedy and, a few pictures later, we now have our own guide on this fairly common problem. Here's how to cure it.. First off, remove the central air vent.
That's the hard part out of the way. Now the small black connector going into the clock on the right needs to be removed. I found it was quite tight. A thumb nail either side of the connectors lips accompanied with a backwards push popped it off easily.
I left it off for five minutes so that the clock was fully discharged of any current.
After 5 minutes, reconnect the clock lead.
Reinsert the central vent.
Adjust the clock to the correct time using a pen point.
Now, if anybody out there googles "British owned and run MG enthusiasts forum clock fix!" Or similar.. they should end up right here at the T-Bar. :lol:
Later that same day...
'The job's a good un'. :broon:
Last Edit:12 years 5 months ago by Leigh Ping
Last edit: 12 years 5 months ago by Leigh Ping.
The following user(s) said Thank You: Ozzy, ianovic
Replied by Yellow Peril on topic Re: MG Clock running slow (Solved).
Posted 12 years 5 months ago #60946
I will be ever so grateful if you can do the same plan for the Trophy, [mine is not alone]
the hour will not adjust and at present clock is five hours out,
Replied by Ozzy on topic Re: MG Clock running slow (Solved).
Posted 12 years 5 months ago #60948
nice :) my clock has been doing this forever...
guess with the engine missing and the battery disconnected for over 3 weeks now that will also have solved it?
by Ozzy
Replied by Leigh Ping on topic Re: MG Clock running slow (Solved).
Posted 12 years 5 months ago #60952
Yellow Peril wrote: I will be ever so grateful if you can do the same plan for the Trophy, [mine is not alone]
Sure.. Here's my idea. Unplug it.. wait until it shows the correct time and then plug it back in. Would that work Ken?
Posted 12 years 5 months ago #60960
Shirly they wern't designed like that?
My trouble I never remember to reconnect the darned thing until next day, tis me age!
Replied by paulsmgf on topic Re: MG Clock running slow (Solved).
Posted 12 years 5 months ago #60961
Mine has the same problem cant change the hour hand ,when you remove it the hour hand has to be on the hour and then reconnect it on the hour if you get me ?
Posted 12 years 5 months ago #60963
Yellow Peril wrote: Shirly they wern't designed like that? I never remember to reconnect the darned thing until next day
Is your alarm clock broke too?.. and please don't call me Shirley. :lol: :P
Have either you or Paul (Paulsmgf) got any pics of the clocks with the problem please? They paint a thousand words you know. :)
Replied by Forrester on topic Re: MG Clock running slow (Solved).
Posted 12 years 5 months ago #60996
My clock runs very slow so I'll give your solution a try.
Can't understand why it works :(
Forrester.
Posted 12 years 5 months ago #61005
Forrester wrote: Can't understand why it works :(
Me neither Forrester. But it does. :)
Replied by John and Sue on topic Re: MG Clock running slow (Solved).
Posted 12 years 5 months ago #61007
My guess would be a capacitive circuit not discharging correctly: disconnection would allow complete discharge. If this is correct then the problem would gradually reappear.
Last Edit:12 years 4 months ago by John and Sue
Last edit: 12 years 4 months ago by Leigh Ping. Reason: Try not to quote pics :)
Posted 12 years 5 months ago #61009
John and Sue wrote: My guess would be a capacitive circuit not discharging correctly: disconnection would allow complete discharge. If this is correct then the problem would gradually reappear.
Only time will tell. :yesnod: I'll report back if and when that happens. :broon:
Posted 12 years 5 months ago #61019
Its only a wild stab in the dark: when I learned electronics in the 70's it was big old components soldered together on veroboard, and the height of technology was etching your own pcb's. I would guess that the clock would consist of a fairly standard chip? Maybe someone with a more modern grasp can shed further light.
