Re: MG Clock running slow (Solved).
Replied by alanrt54 on topic Re: MG Clock running slow (Solved).
Posted 12 years 3 months ago #61174
Unfortunately it didn't work on my Mk2 F. Its lost 40 minutes overnight.
by alanrt54
alanrt54 wrote: Unfortunately it didn't work on my Mk2 F. Its lost 40 minutes overnight.
Had the same problem with my mk2 F I had to buy a replacement clock.It's done the trick the times been spot on for the last two and a half years.
If you change it make sure you get the right one, tf and mk1 clocks are different wiring I believe.
by Bob
Got the ame problem here , got a second clock to solve the problem but it has the same.
Is there a fix for this problem .
Disconecting and waiting around for the right time and connecting it again is no option for me .
by Devinci
On my MK2 there are 3 separate wires , disconnecting them had no effect , is there a fix for these clocks ?
by Cubmg
Replied by talkingcars on topic Re: MG Clock running slow (Solved).
Posted 3 years 8 months ago #195362
I gave up on mine 10 years ago and have set the clock on my aftermarket head unit.
by talkingcars
Time to create page: 0.520 seconds
