LED Rear Light Bulbs??
  • Visitor
  • Visitor
LED Rear Light Bulbs?? was created by a Guest
Posted 12 years 2 months ago #65379
Anyone have experience of LED bulbs?
I bought some White 9 led 12v 5w bulbs and fitted to one side of car to see the difference...
The led has been fitted to drivers side(right hand) and has made the light looking from the rear look very pink and not as bright as the standard bulbs...
Last Edit:12 years 2 months ago by a Guest
Last edit: 12 years 2 months ago by a Guest.
Replied by paulsmgf on topic Re: LED Rear Light Bulbs??
Posted 12 years 2 months ago #65382
I;m sure leigh did it and they looked much better ,i'll see if i can find the thread
Replied by David Aiketgate on topic Re: LED Rear Light Bulbs??
Posted 12 years 2 months ago #65449
I toyed with these for a while, and found that red leds give a better colour as the white is too blue/white and gives the effect you noticed.
The other problem is that a lot of these leds aren't actually as bright as a standard incandescent.
I now have leds Brake/side lights in the Nissan, but they have something like 12-15 leds on each 'bulb'.
Also the Cree type leds are much brighter. (Look like a little yellow pcb rather than a bulb) This type
5x 5 SMD LED XENON WHITE SIDE LIGHT BULB 501 W5W T10 PUSH WEDGE 360 DEG UK
Buy It Now
Last Edit:12 years 2 months ago by David Aiketgate
Last edit: 12 years 2 months ago by David Aiketgate.
  • Visitor
  • Visitor
Replied by a Guest on topic Re: LED Rear Light Bulbs??
Posted 12 years 2 months ago #65452
Quick question, sorry David, it's not a hijack :sofa:
Leds in the front grills, legal or illegal :-?
Posted 12 years 2 months ago #65454
Depends on what and where
  • Visitor
  • Visitor
Posted 12 years 2 months ago #65459
Behind the grills, in red :whistle:
Posted 12 years 2 months ago #65468
Illegal to use on the road. Only allowed to show white to the front(or amber indicator lights)
  • Visitor
  • Visitor
Posted 12 years 2 months ago #65516
Thank you David ..
White :sick:
Replied by Yellow Peril on topic Re: LED Rear Light Bulbs??
Posted 12 years 2 months ago #65518
you are only allowed to show 2 dipped headlights and two indicators to the front, running lights must go out when headlamps dipped are on,
at the rear you can have as many orange indicators, red tail lights but only max 2 fog lamps, I think you are restricted to two stop lamps, but LEDs white to the front red/orange to the rear are ok and underneath, [how] could be orange, definitely no BLUE
Replied by John and Sue on topic Re: LED Rear Light Bulbs??
Posted 12 years 2 months ago #65530
I always understood that it was illegal to show any blue lighting on a vehicle unless emergency service obviously, also green as this is designated for Doctors on emergency call.
So I was wondering: most of the Citroen Saxo's/Vauxhall Novas etc with 1 litre engines, 9 inch tailpipes and 4 megawatt stereos etc driven by the sub-species doleyscrote maccydee drivethru chavvus seem to display blue lamps: is it that they are sold for show use and fitted by them illegally for road use?
Why do I get the feeling that as a (mainly) law abiding road tax paying fully insured mature driver I fitted some, the Plod would be over me like a rash?
  • Visitor
  • Visitor
Posted 12 years 2 months ago #65534
So I can put white ones on the front in my grills and wire them to the headlamps and that is ok :-?
Posted 12 years 2 months ago #65542
Yellow Peril wrote: you are only allowed to show 2 dipped headlights and two indicators to the front, running lights must go out when headlamps dipped are on,
Also......... limited to 2 stop lights????
One on each side + one in the middle last time I looked on our cars !
wot about front fogs: they display when dipped beams are on, and on my standard Jag, which I presume is street legal, the front fogs also operate independently of the dip beam? Also, sidelights remain on both on main and dip beam. So, you can have dip or main, sidelights and foglights on at the same time at the front.
Driving lamps (spotlights) have to be switched to go out on dip as you say.
Jan, I wouldn't like to call the white led's at the grille: I have seen a lot of trucks with these in the rad grille however. Also aforementioned Saxo Scrotes....doesn't mean they are legal however!
Last Edit:12 years 2 months ago by John and Sue
Last edit: 12 years 2 months ago by John and Sue.
Time to create page: 1.569 seconds
