Badges
Thanks, Ned.
- Leigh Ping
MG Black/Silver Gel Bonnet Badge Choice of Sizes.
Measure up Ned, as sizes differ.
Leigh Ping wrote: Bonnet, Boot and Wheel Centre badges - Great looking gel badge replacements and fixing guide.
Thanks Leigh. Anyone know the sizes for front and rear badges on a 1996 MGF? (don't have access to car atm)
- a Guest
- Visitor
- John and Sue
Can't help with the size: we have a TF and I think they are different size to an F
Note: different suppliers give two possible dimensions, very close to one another: one is the distance across flats to the outside edges of the Octagon, the other to the inside of the raised outer section of the Octagon. In the case of the TF, IIRC, the dimensions given were 65 and 70mm: the badge will be the same size!
I'm sure an F owner will be along soon to help!
- Leigh Ping
At Jans brilliant BBQ I noticed my TF badges seemed much bigger than her F's.John and Sue wrote: I'm sure an F owner will be along soon to help!
- John and Sue
- John and Sue
- a Guest
- Visitor
They are the first one I bought ended up going on my Mud flaps :slapme:
The F ones are much smaller and a perfect fit :broon:
Dave go and take your meds
- John and Sue
Just this second checked my '96 and inside diameter is 55mm front and back. I believe inside diameter is what needed as new badge sits in frame of old.
So I need to order the 54mm ones from the drop down box?
44mm octagon for wheel centres.
