Bearings online 5% Discount offer to T-Bar members
Bearings online 5% Discount offer to T-Bar members was created by cjj
Posted 12 years 3 months ago #70323
I am going to build a front end (suspension) using the spare subframe and suspension bits that I have.
As I am going to build up the hubs with new bits I thought I would start looking into wheel bearings and whether there are good and bad ones.
I think the general internet opinion are SKF (VKBA 1452) or Timkin are the best, although from what I have read the SKF kit has the Timkin bearing in anyway.
While they are reported as being some of the best you can get, they are £60 - £100 each.
http://www.mister-auto.co.uk/en/wheel-bearing-kit/skf-vkba-1452_g654_a050VKBA!1452.html
So my questions are
Does anyone use SKF/Timkin bearings over the generic e-bay ones?
Does anyone know where I can get them at a good price?
If I use e-bay Trupart bearings or similar I can buy 4 wheel bearing kits for the price of 1 SKF kit.
I know most of you will be on the side of just buy the Trupart type, but is there anyone out there who likes fitting quality stuff and can tell me the benifits? Are the SKF tapered rollers as opposed to Trupart being standard?
Last Edit:12 years 3 months ago by cjj
Last edit: 12 years 3 months ago by Leigh Ping. Reason: Changed the title to reflect the offer to members :)
Replied by Jack of Hearts on topic Re: Wheel bearings - Do you get what you pay for?
Posted 12 years 3 months ago #70328
I work for a bearing manufactor (well primarily) and after I visited the skf factory. I'd buy the cheapist bearings I can find ;)
Replied by cjj on topic Re: Wheel bearings - Do you get what you pay for?
Posted 12 years 3 months ago #70330
Why?
Was it dirty?
Was it the wrong colour?
Are you just tight? ;)
Last edit: 12 years 3 months ago by cjj.
Posted 12 years 3 months ago #70343
Actully the factory was clinque clean, all bearings are the made the same using the same steel. What they specialised in was bearing placement, and root cause analysis to failure.
Replied by Laz1957 on topic Re: Wheel bearings - Do you get what you pay for?
Posted 12 years 3 months ago #70358
root cause analysis - why? why? why? why? why? :lol:
by Laz1957
Replied by John and Sue on topic Re: Wheel bearings - Do you get what you pay for?
Posted 12 years 3 months ago #70380
In my industry we only use premium bearing makes: RHP, Timken, SKF.
Bearings from the exotic East (China, Korea) do not have a good rep in industry.
If you can determine the bearing code (usually stamped on the inner race) a good industrial bearing factor, eg Hayleys, can crossmatch and offer you a price.
Replied by bensewell on topic Re: Wheel bearings - Do you get what you pay for?
Posted 12 years 3 months ago #70390
My cheap 45 quid bearing job done by the garage has lasted so far
Replied by quick_spider on topic Re: Wheel bearings - Do you get what you pay for?
Posted 12 years 3 months ago #70391
I've had OE bearings (bought new hubs/carriers) fail in under 5k - I just fit the cheap ones as they've done me okay so far!
Replied by Titanium on topic Re: Wheel bearings - Do you get what you pay for?
Posted 12 years 3 months ago #70392
This is a topic I was investigating:
SKF VKBA1452 is a kit including X type 4 contacts BALLs bearing, the equivalent Timken is K74214.
I was unable to find the tech spec.s of the Timken bearing
Assuming it should be a tapered rollers bearings, in such a case it is highy recommended to replace ball bearings with rollers, due to the higher load bearing capa)
i.e. Elise parts is selling a tapered roller bearing, manufactured according to their specs. Why manufacture a own bearing when you can use the Timken bearing
A key point concerning bearing service life is the preload
Posted 12 years 3 months ago #70558
Wheel bearings trucks arnt ball bearings anyway :)
Posted 12 years 3 months ago #70562
Looks like these might be the winners. :broon:
http://www.bearings-online.co.uk/item/Brand_Automotive-Bearings_JRM3938A-TIMKEN_0_0_1624_0.html
Posted 12 years 3 months ago #70565
Timken have a good rep :broon:
Time to create page: 0.535 seconds
