How to clean a coolant expansion tank.
Replied by bensewell on topic Re: How to clean a coolant expansion tank.
Posted 11 years 2 months ago #128548
I also used a 16mm drill circle thing so the fit is super tight. Some pics.
The following user(s) said Thank You: reevepal
Replied by Keymaster on topic Re: How to clean a coolant expansion tank.
Posted 7 years 11 months ago #174517
I want to try this for myself, checked the cupboards and no rice of any kind, but found a pack of Ainsley Harriet's cous cous will that do?
Cannot think of any other use for it. :lol:
Replied by David Aiketgate on topic Re: How to clean a coolant expansion tank.
Posted 7 years 11 months ago #174524
I agree that is the best use for cous cous. :yesnod: Dreadful stuff. :nonod:
Replied by g4wam on topic Re: How to clean a coolant expansion tank.
Posted 7 years 11 months ago #174535
well done Leigh another ace HOW TO
I have used the diswasher tab method and it certainly cleared out the coolant system prior to changing the coolant.
But never been able to get the bottle that clean so will try your method
How did you get permission to use the kithen sink!!
Happy Christmas to all
Mike
by g4wam
Replied by Gers on topic Re: How to clean a coolant expansion tank.
Posted 6 years 5 months ago #186247
Just a note of warning: Bleach + Vinegar = Toxic Chlorine Gas. While the combination does create a good disinfectant, these two common cleaning agents should never be used at the same time. Why? ... Adding any weak acid to bleach will release toxic chlorine and chloramine vapours
by Gers
Replied by mgtfbluestreak on topic Re: How to clean a coolant expansion tank.
Posted 6 years 5 months ago #186248
Always wear the correct safety clothing and dispose of the rice carefully.
Replied by cairnsys on topic Re: How to clean a coolant expansion tank.
Posted 6 years 5 months ago #186271
Gers wrote: Just a note of warning: Bleach + Vinegar = Toxic Chlorine Gas. While the combination does create a good disinfectant, these two common cleaning agents should never be used at the same time. Why? ... Adding any weak acid to bleach will release toxic chlorine and chloramine vapours
That's why you shouldn't put bleach down the toilet and then pee down it afterwards!!! :coat:
Replied by Rich in Vancouver on topic Re: How to clean a coolant expansion tank.
Posted 5 years 7 months ago #190097
It's a long time since this post has seen any action but I have to say The Method Works! :)
I got quite a bit of the brown residue out with a bottle brush (It was nowhere near clean though!)
then followed with an overnight soak in hot water with dishwasher soap. Then a good rinse followed by the shake with a mixture of
bleach and rice (Basmati :) )
The only thing I would add to the instructions is, if you have a coolant level float in the tank to make sure that it isn't stuck in place with
grains of rice. I also covered the cap opening with plastic wrap to keep rice out of the valve. One other tip.....I used the pointy ends off tubes of sealant to plug the holes while shaking. (All but the smallest one which I plugged with a finger.) It saves getting bleachy rice all over the kitchen.
Last Edit:5 years 7 months ago by Rich in Vancouver
Last edit: 5 years 7 months ago by Rich in Vancouver.
Posted 5 years 7 months ago #190099
Yes I remember using this method of rice and bleach...after I cleaned the tank i had a good inspection to see how clean it was and noticed stress cracks coming from the outlet tube..
Time to create page: 0.576 seconds
