Windscreen washers
Thanks hun! Rep left! :respect:
It's amazing, the number of previously-unknown lifeforms that can grow in washer fluid! Ughh!
Another thing to check if you have trouble with your flow( no-not the old prostate trouble again!) is the non-return valve. It can also get blocked or just fail.
It is the black circular object in the pipes, near the bonnet end.
TBH, I removed mine and binned it. I haven't really noticed the loss!:bye:
2000 MGF 1.8i SE Wedgewood
2002 MG ZS200 Trophy Blue
1999 Land Rover Discovery series 2 TD5
Kara;8294 wrote: Ooh what handy advice - I will give it a go! How did you flush out the pipes then?
I ran a solution of warm soapy water through using air presure from a compressor, my daughters partner has one rigged up in their garage, very handy! In fact he is becomming my tame mechanic, dosn't think much of MG's though loves Jeeps, he is also replacing the engine in his 1986 BMW 318i with one from a Toyota Corolla, some twin cam 1.8 liter with about 105kw, more power than the BM engine and cheaper.
from inside;
and outside;
a very cheap and easy mod that everyone should be capable of doing both financially and physically. :yesnod:
FM :rolleyes:
Hah, I like it!FrankM83;8341 wrote: did this and to be honest nearly crashed when I cleaned the windscreen during driving as I hadn't expected that much water LOL
Gos;8321 wrote: took some pics when I did mine;
from inside;
and outside;
bugger me what a difference... whenever i get my bursary ill be out trawling the scrappys!
FM :rolleyes:
FrankM83;8359 wrote: probably it's cheaper buying them from ebay, than wasting time runing around in scrappys, they're only £5 - £7
why do i never think of ebay lol.... when i have more than 58p i shall be shopping
- Leigh Ping
