One off boot lid
One off boot lid was created by Diesel Destroyer
Posted 12 years 2 months ago #84317
I don't like making life easy for myself...
I'm starting a boot lid build.. Will take about 60 hours to build (only an estimate)
First job.... Why is the seam on the back of the TF boot lid? Cost... So first up remove the paint with a wire brush bit in a drill
The seam will then be welded up and ground back and smoothed
The key lock is a fav place for rust to start and looks ugly... So same treatment for that
Sheet steel will be cut and welded in
Same goes for the centre bake light
It's too will have plate welded in and smoothed
Badge holes will be welded up too.. Holes welded up
The boot vents are being doubled too..
JDL spoiler bonded on and smoothed in..
Will post update pics if there is any interest
Last Edit:12 years 2 months ago by Diesel Destroyer
Last edit: 12 years 2 months ago by Diesel Destroyer.
Replied by Kameleon on topic Re: One off boot lid
Posted 12 years 2 months ago #84325
Have you got the lip spoiler yet? Curious as to how well it fits..
Replied by bensewell on topic Re: One off boot lid
Posted 12 years 2 months ago #84327
I've seen stick on ones for audit TT / volvos I'm sure with a bit of sanding / priming it would look a treat.
Replied by Diesel Destroyer on topic Re: One off boot lid
Posted 12 years 2 months ago #84328
I've ordered it... But it takes 3-4 weeks to come as they are made to order
Will post pics once it finally turns up
Replied by Daniel-Cook on topic One off boot lid
Posted 12 years 2 months ago #84343
You gonna run a electric solenoid for opening? As I just run a mg zr bonnet cable into the cabin and it works a treat!
Posted 12 years 2 months ago #84358
Yer... 65lbs metal solenoid to pop the boot... Along with gas struts to open it
Replied by cjj on topic Re: One off boot lid
Posted 12 years 2 months ago #84391
Diesel Destroyer wrote: The boot vents are being doubled too..
These are things I have planned, but I was going to get the boot moulded in CF or fibre glass once finished.
Just hope it doesn't take as long as the bonnets.
Posted 12 years 2 months ago #84396
Carbon or fibre glass would be a better bet Clive...
I was always put off by the fact that no one has built one that uses the existing boot catch.. So they use pins etc
Metal is cheap and repairing it is simple
But would deffo opt for carbon or fibre glass if there was one that used the standard boot catch
  • Visitor
  • Visitor
Replied by a Guest on topic Re: One off boot lid
Posted 12 years 2 months ago #84397
Any news on the Proto that went awol on ebay Clive ?
Replied by rover-25x on topic Re: One off boot lid
Posted 12 years 2 months ago #84815
Been looking forward to this part of the build, need to smooth mine too. ;)
Posted 12 years 1 month ago #85080
Done it!!!
I now have a boot lit that opens fully on its own once the popper is popped
The boot lid will not blow down in the wind either
VW Jeta gas struts used (same as my under bonnet ones)
Replied by andywatson on topic Re: One off boot lid
Posted 12 years 1 month ago #85093
Here's a video of Allan's self opening boot lid. Pretty Cooooool! we've both had trouble uploading to T-Bar so here is a link.
To upload a video like this:-
Copy the ID code ie BbI_Dyw5CLI,
click on the film strip(next to ebay)
In the provider window scroll down to youtube and then enter the ID code.
Press insert video.
If a jobs worth doing, it's worth overdoing
Last Edit:12 years 1 month ago by andywatson
Last edit: 12 years 1 month ago by David Aiketgate.
Time to create page: 0.536 seconds
