rear trailing arm bushes
rear trailing arm bushes was created by nuttah69
Posted 11 years 10 months ago #104406
Hello, i have been given the news that my rear trailing arm bushes (both sides) are worn, would it be possible
for a step by step guide to how these are replaced please
many thanks
Replied by David Aiketgate on topic rear trailing arm bushes
Posted 11 years 10 months ago #104413
F or TF?
Inner or outer bush?
Replied by nuttah69 on topic rear trailing arm bushes
Posted 11 years 10 months ago #104885
its an f and i think its the outers because its the one with two big washers on eather side of the bush and its the end of the bar with the nut on the end.. thanks
Replied by Diesel Destroyer on topic rear trailing arm bushes
Posted 11 years 10 months ago #104888
Easy to do..
Jack up one side.. Wheel off..
Rear arm off (bolt each end)
Undo the trailing arm (one through subframe, one bolt to hub and the tie bar through the middle)
Burn or saw the old bushes out (do all three)
Clean and paint arm.. Replace with poly.. silly not to realy
Re-fit
Personally Id replace the M12 bolts with new.. and locktite the bolts that go into the subframe
The following user(s) said Thank You: bensewell, nuttah69
Posted 11 years 10 months ago #104889
Where abouts are ya based?
Someone local may be able to help?
The following user(s) said Thank You: nuttah69
Posted 11 years 10 months ago #104894
i am in hurley atherstone north warwickshire
Posted 11 years 10 months ago #104895
If you're handy on the spanners then give it a go..
Just make sure you use axle stands and not just a jack
:broon:
Last Edit:9 years 9 months ago by Diesel Destroyer
Last edit: 9 years 9 months ago by David Aiketgate. Reason: sp
Time to create page: 0.504 seconds
