Well... Flopsy is sick again!
As I reversed off the driveway, I noticed that the clutch seemed really heavy, but thought it would get better as I drove.
I got onto the main road, and every time I changed gear, and went back to the accelerator, she suddenly revved 1-2K higher than normal and then dropped back down.
I didn't go for a long drive or anything to see if the problem went away. It was dark, and I needed to get back to where I was staying, so I took her home and sorted out a lift instead.
Any thoughts or advice etc. Is she broken badly? Do I just need to take her for a long drive and it will go away?
It's really sucked not having a car for the week... Each morning, I'm leaving the house at 6:30 and walking two miles to the train station. I'll be back home for the weekend, so really need to make it better if I can!
Please help Flopsy! :grouphug:
Replied by David Aiketgate on topic Well... Flopsy is sick again!
Posted 14 years 10 months ago #8799David
Kara;8798 wrote: Sorry to hear Flopsy is having another stressy. No idea what that could be so I'll just wish her better! :yesnod:
Thank you hun :grouphug:
David Aiketgate;8799 wrote: Sounds like the clutch arm is sticking. You can lubricate the arm and work it back and forth. That is often enough to free it off.:yesnod:
Er, how would an idiot go about doing that?! :whistle:
Posted 14 years 10 months ago #8803Take off engine cover, locate clutch slave cylinder and the arm, grease arm, operate clutch pedal in and out until it frees off. It's better if two people do this - one to pump the clutch, the other to watch the arm and grease as necessary.Alias;8801 wrote:
I'm sure Clive will have a photo if you pm him.:yesnod:
David Aiketgate;8803 wrote: Take off engine cover, locate clutch slave cylinder and the arm, grease arm, operate clutch pedal in and out until it frees off. It's better if two people do this - one to pump the clutch, the other to watch the arm and grease as necessary.
Thank you. I'll have a look at that over the weekend and see if I can make her better
Posted 14 years 10 months ago #8932The corrugated plastic tube, and absorbent material in it, is holding oil/grease onto the relevant part of the clutch arm.
This is a DIY attempt(successful) to keep the clutch arm lubricated and prevent it seizing.:yesnod:
David Aiketgate;8932 wrote: OK, here's what I wanted to post, but Photobucket was being a pain!
Thank you very much. Is there any specific grease I should use?
Posted 14 years 10 months ago #8939Anything, such as engine oil, if you use the DIY thingy. Or you can get a spray can of White lithium grease at the likes of Halfords that is very good. As you can spray it on and it then sets, coating the arm. Then you don't need the DIY effort.Alias;8937 wrote: Thank you very much. Is there any specific grease I should use?
Just don't use WD40.
- a Guest
- Visitor
I got mine fixed at a local clutch place last summer... can't remember exactly how much it was, but I reckon around £350.
thedigger;8948 wrote: Sounds a lot like a failing clutch too. Do you get a putrid lingering smell when it does it? Best way to test a failing clutch is to drive up a hill..... if you really struggle to make it, your clutch is probably on its last legs.
sadly sounds like a clutch going to me too... but i know a sticky arm can cause the same symptoms
£350 sounds cheap my best quote was closer to £450... so i did it myself (with a little... ok allot of help from CJJ!)
It doesn't sniff bad, and I've never noticed it sticking on hills...
Adam-MGTF;8953 wrote: sadly sounds like a clutch going to me too... but i know a sticky arm can cause the same symptoms
£450?! I don't have £450?! Arrrggg!
I've got a friend that is going to try to look at it tomorrow if it stops raining. *fingers crossed*
