Well... Flopsy is sick again!
Well... Flopsy is sick again! was created by alias
Posted 14 years 10 months ago #8795
After leaving Flopsy parked for 5 days, I took her out to get some petrol. (The days she was parked, the temperature didn't drop to freezing.)
As I reversed off the driveway, I noticed that the clutch seemed really heavy, but thought it would get better as I drove.
I got onto the main road, and every time I changed gear, and went back to the accelerator, she suddenly revved 1-2K higher than normal and then dropped back down.
I didn't go for a long drive or anything to see if the problem went away. It was dark, and I needed to get back to where I was staying, so I took her home and sorted out a lift instead.
Any thoughts or advice etc. Is she broken badly? Do I just need to take her for a long drive and it will go away?
It's really sucked not having a car for the week... Each morning, I'm leaving the house at 6:30 and walking two miles to the train station. I'll be back home for the weekend, so really need to make it better if I can!
Please help Flopsy! :grouphug:
by alias
Replied by kara on topic Well... Flopsy is sick again!
Posted 14 years 10 months ago #8798
Sorry to hear Flopsy is having another stressy. No idea what that could be so I'll just wish her better! :yesnod:
by kara
Replied by David Aiketgate on topic Well... Flopsy is sick again!
Posted 14 years 10 months ago #8799
Sounds like the clutch arm is sticking. You can lubricate the arm and work it back and forth. That is often enough to free it off.:yesnod:
Replied by alias on topic Well... Flopsy is sick again!
Posted 14 years 10 months ago #8801
Kara;8798 wrote: Sorry to hear Flopsy is having another stressy. No idea what that could be so I'll just wish her better! :yesnod:
Thank you hun :grouphug:
David Aiketgate;8799 wrote: Sounds like the clutch arm is sticking. You can lubricate the arm and work it back and forth. That is often enough to free it off.:yesnod:
Er, how would an idiot go about doing that?! :whistle:
by alias
Posted 14 years 10 months ago #8803
Take off engine cover, locate clutch slave cylinder and the arm, grease arm, operate clutch pedal in and out until it frees off. It's better if two people do this - one to pump the clutch, the other to watch the arm and grease as necessary.
I'm sure Clive will have a photo if you pm him.:yesnod:
Posted 14 years 10 months ago #8923
David Aiketgate;8803 wrote: Take off engine cover, locate clutch slave cylinder and the arm, grease arm, operate clutch pedal in and out until it frees off. It's better if two people do this - one to pump the clutch, the other to watch the arm and grease as necessary.
Thank you. I'll have a look at that over the weekend and see if I can make her better :)
by alias
Posted 14 years 10 months ago #8932
OK, here's what I wanted to post, but Photobucket was being a pain!
The corrugated plastic tube, and absorbent material in it, is holding oil/grease onto the relevant part of the clutch arm.
This is a DIY attempt(successful) to keep the clutch arm lubricated and prevent it seizing.:yesnod:
Posted 14 years 10 months ago #8937
David Aiketgate;8932 wrote: OK, here's what I wanted to post, but Photobucket was being a pain!
Thank you very much. Is there any specific grease I should use?
by alias
Posted 14 years 10 months ago #8939
Alias;8937 wrote: Thank you very much. Is there any specific grease I should use?
Anything, such as engine oil, if you use the DIY thingy. Or you can get a spray can of White lithium grease at the likes of Halfords that is very good. As you can spray it on and it then sets, coating the arm. Then you don't need the DIY effort.
Just don't use WD40.
  • Visitor
  • Visitor
Replied by a Guest on topic Well... Flopsy is sick again!
Posted 14 years 10 months ago #8948
Sounds a lot like a failing clutch too. Do you get a putrid lingering smell when it does it? Best way to test a failing clutch is to drive up a hill..... if you really struggle to make it, your clutch is probably on its last legs.
I got mine fixed at a local clutch place last summer... can't remember exactly how much it was, but I reckon around £350.
Replied by Adam-Mgtf on topic Well... Flopsy is sick again!
Posted 14 years 10 months ago #8953
thedigger;8948 wrote: Sounds a lot like a failing clutch too. Do you get a putrid lingering smell when it does it? Best way to test a failing clutch is to drive up a hill..... if you really struggle to make it, your clutch is probably on its last legs.
sadly sounds like a clutch going to me too... but i know a sticky arm can cause the same symptoms
£350 sounds cheap my best quote was closer to £450... so i did it myself (with a little... ok allot of help from CJJ!)
Posted 14 years 10 months ago #8956
It doesn't sniff bad, and I've never noticed it sticking on hills...
Adam-MGTF;8953 wrote: sadly sounds like a clutch going to me too... but i know a sticky arm can cause the same symptoms
£450?! I don't have £450?! Arrrggg!
I've got a friend that is going to try to look at it tomorrow if it stops raining. *fingers crossed*
by alias
Time to create page: 0.531 seconds
