Race engine mounts
- Diesel Destroyer
Yes they are expensive :omg:
Yes they are recommended for track day/ high BHP cars
No you dont have to have them
No the standard 14 year old knackered rubber item isnt the same :oops: :bang:
Yes I have ordered mine today :woohoo:
- Diesel Destroyer
4-2-1 maifold
Janspeed sports CAT
Dan Cooke's coil overs
Race engine mounts
Double DIN bits
Paid for front brake conversion
Titan ITBs and air box
:oops:
- Diesel Destroyer
- Diesel Destroyer
Cam belt end... The bar and bracket get chucked
Gearbox end (I seam welded the mount) Vibra Technics mount goes into this
Lower engine mount
The kit supplied is a straight bolt on with no alterations required
I'll probably end up getting the standard ones as, well I don't know, are there any alternatives I wonder, and do you need to drop the subframe.
Looking good now Allan, glad to see your up and at it.
Tone
- Diesel Destroyer
Undo lower engine mount... Then you can jack up the engine to get the cam belt end one out (most common one that fails) its a fiddle but I've done one..
There are no alternatives... Yet.. But someone on here is looking to develop a polybushed item..
The factory standard ones are ok.. But if you plan big power or hard track days it makes sense to fit the best
Elise parts do a polybushed mount.. But no idea if it fits the F/TF without modding
