Engine Bay Cooling Fan (No Switch)
When the engine was removed I also took out the engine bay cooling fan for cleaning and painting, I ran it from a battery to check the brushes and bearings which were fine.
On my 03 Sunstorm you check the function of the switch with a hairdryer to test the fan; is the fan now redundant on my 05 Stepspeed, I couldn't see the factory fitting the fan if it’s never going to run, but where is the signal coming from to energize it?
Attached is an image of the blank space for the switch but there is no evidence of one ever been fitted.
- John and Sue
Replied by John and Sue on topic Engine Bay Cooling Fan (No Switch)
Posted 11 years 6 months ago #111344It will be all right in the end. If it isn't all right yet, then it is not yet the end..
Replied by David Aiketgate on topic Engine Bay Cooling Fan (No Switch)
Posted 11 years 6 months ago #111446David
- John and Sue
Posted 11 years 6 months ago #111453John faints............
Posted 11 years 6 months ago #111464David
Not sure why this has changed on later models and could not argue the logic either way as some positives and negatives for both systems.
The bottom line is; it works.
Thanks for your help.
- John and Sue
Posted 11 years 6 months ago #111601Happy to help.
