help to Identify this relay please
help to Identify this relay please was created by carlvk
Posted 11 years 4 months ago #122101
I need to replace it.
It is the round one on the interior fuse board.
Last Edit:11 years 4 months ago by carlvk
Last edit: 11 years 4 months ago by carlvk.
Replied by bensewell on topic help to Identify this relay please
Posted 11 years 4 months ago #122109
Carl you link is not working for me
Replied by David Aiketgate on topic help to Identify this relay please
Posted 11 years 4 months ago #122113
The part number for the relay is DJP8473
I don't know what it does.:shrug:
Replied by carlvk on topic help to Identify this relay please
Posted 11 years 4 months ago #122115
Its driving me potty now (OCD Alert!)
I picked one up from a breakers, Slater Bros in Brum, Surly but cheap!
I honestly cant tell any difference. Everything seemed to be working before and after. :nonod:
by carlvk
Posted 11 years 4 months ago #122119
What made you think it needed changed? :-?
Posted 11 years 4 months ago #122122
<blush>
1.I was tracking an electrical fault without success and with a shortage of time and patience.
2.it was hot in the panel everything else checked out fine.
3. and this is the most important bit...... I separated the top from the bottom
<blush>
Posted 11 years 4 months ago #122123
Done a bit of research and it's the indicator flasher unit. :broon:
Posted 11 years 4 months ago #122125
Thanks
Bizarrely I checked the indicators and they were working when the unit was in the boot.
I think I need to lie down
by carlvk
Posted 11 years 4 months ago #122130
This is what I found.
Unless it means Headlamp flasher unit. Try main beam/dip
Last Edit:11 years 4 months ago by David Aiketgate
Last edit: 11 years 4 months ago by David Aiketgate.
Posted 11 years 4 months ago #122173
I can confirm it is the cigar lighter relay.
Between deluges I removed the replacement and no power to cigar lighter. I was going to prove by moving R1 but I couldn't get it out and the rain started again. There must be a clip holding R1 in I will take a better look in the dry with a torch.
I wouldn't mind betting R1 is the indicator relay and the "map is not the territory". Thanks for your help and the image David
I have adjusted the image for my 1997 mk1 mgf mpi
Posted 11 years 4 months ago #122176
Thanks Carl, I will copy your amended diagram and file for future reference. I can bet the question will be asked again so :broon:
Time to create page: 0.539 seconds
