K series modding and tuning
- Diesel Destroyer
So I thought Id start a 'discussion' thread about mods for the K series..
My mate recently paid to have his head 'ported and polished' .. There is often talk about this..
Personally Id go for one of the known names if you plan to have this done
My head was done by Hellier performance.. Its more than just enlarging and smoothing the inlet and exhaust ports..
The water ways too need cleaning out of the casting marks to allow better water flow through the head..
The head was chemically cleaned (hence the as new look) then the valves all made back into the head and checked carefully
Before porting and polishing Hellier check the hardness of the head
Note the water ways all now cleaned out
The water ways before
Another before pic
We've already looked at his exhaust ports and they look standard.. so this weekend we are going to remove his inlet manifold and have a look.. Has the head seen any work? Guess we'll find out Sunday
- Diesel Destroyer
Replied by Diesel Destroyer on topic K series modding and tuning
Posted 11 years 5 months ago #122610Diesel Destroyer.. 'The bringer of dreams'
- Diesel Destroyer
Posted 11 years 5 months ago #122613The block was then machined to make it a 1.9
New pistons and new liners
Again the block tested before any work was done on it
- Diesel Destroyer
Posted 11 years 5 months ago #122614Mr Quick_Spiders sump baffle got fitted.. This helps to minimise oil movement in the sump during hard cornering
The crank (standard one) was then balanced.. as was the brand new EN24 fly wheel and clutch cover.. this minimises the vibrations at high RPM.. so the redline can now be raised from 7,400 to 8,200
- Diesel Destroyer
Posted 11 years 5 months ago #122615The older type VVC belt is used as its apparently 1mm wider than the new VVC belt
Manual tensoner used insted of the auto one.. which can let go at higher RPMs
The TF 160 VVC engine has been converted to non VVC and some light weight Vernier pullies used to ensure accurate timing is achived
The alternator too gets a lightened pulley (weighs one third of the standard item)
- Diesel Destroyer
Posted 11 years 5 months ago #122616Diesel Destroyer.. 'The bringer of dreams'
What bhp/torque you expecting???
KV6 seems very difficult to get around or above 200 bhp.
- Diesel Destroyer
Posted 11 years 5 months ago #122619Janspeed Sports CAT
Janspeed large bore 4-2-1
12.9 bolts with loctite used throughout
Vibratechnics mounts used
Greabox mount seam welded and Vibratechnics mount
Clutch slave mount cross braced and gussets added
Spheres on custom made hoses
- Diesel Destroyer
Posted 11 years 5 months ago #122620Instead a Laminova oil cooler will go on..
The anti roll bars are custom too (80% stiffer).. as are the drop links and the drop link mounts
The subframe was seam welded
The subframe mounts are all solid.. and the smaller ones beefed up
- Diesel Destroyer
Posted 11 years 5 months ago #122621petetf160 wrote: Interesting project, I suppose you are saving a lot using your labour, but knowing how the costs mount up, was wondering if the mod would be cheaper to fit a KV6 engine.
I spoke to Hellier prior to getting him to do the engine.. Asked about the KV6.. He reckons a properly sorted K will leave it for dead..
I paid Hellier to do the head and to build the engine as Im no engine builder
My mates head has 'apparently' been ported and polished.. by someone unknown.. Its anyones guess what we will actually find..
Personally if anyone wants some head work done.. go for a reputed K series tuner
Dave Andrews
Sabre Heads
Hellier Performance
The water ways need doing during the work
My engine is not 'the ultimate' K series.. far far from it
Im running 633 cams.. If I ran better cams Id see more power.. but want the car drivable around town
The Emerald ECU will need setting up to get the most out of the engine
